My nuc x15 control center automatically turns on passive cooling and numeric keypad every time it is turned on, and the fan scheduling is not very active, many times the notebook is already very hot, but the fan is still spinning very slowly. I hope to add a linear scheduling of fans in the next version of the Control Center update, and then this linear scheduling player can change it themselves. At the same time, we hope to fix the situation that the console restarts passively dissipate heat and the numeric keypad opens for no reason.
Hello davew2,
To have a better understanding of your issue, I want to confirm if you are referring to the Control Center for the Intel® NUC application or if you mean the Intel® NUC Software Studio Services.
Also, since the issue is related to the fan profile, have you tried selecting a different fan profile on the BIOS settings?
Jean O.
Hello davew2,
I hope you are doing fine.
Jean O.
Hello davew2,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
I would also add that I have shared your feedback with the corresponding team.
Best regards.
Jean O.
