Gigabyte AORUS GTX 1080 Gaming Boxに
ZOTAC GTX660,RD-RX6500XT-E4GB/SFを入れて接続しましたが
認識しませんでした
GF-GT710-E1GB/HSは認識しドライバがインストールされ問題なく使えています
Gaming Box及びNUCのBIOSは最新です
次にm.2→PCIE変換アダプタ R43SGを試してみました
RD-RX6500XT-E4GB/S 認識せず
GF-GT710-E1GB/HS 使用可能
でした
RadeonはNUC11で使えないのでしょうか
Hello townsx,
Thanks for all the time, in this case, we can confirm that the NUC supports external video cards. However, M.2 adapters are not supported, if a regular M.2 storage device works as expected then the combination with other devices/adapters is something that you may need to try/test on your own since it is out of specifications.
Thanks for your comprehension.
Deivid A.
Hello townsx,
Thank you for posting on the Intel® communities. I understand you are having issues with your Intel® NUC 11 Performance kit - NUC11PAHi5.
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
- Download the Intel® SSU and save the application on your computer: https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
- Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click Next and click Save.
2. Is the Intel® NUC 11 Performance kit - NUC11PAHi5 a new device?
3. How are you connecting a graphics card to the NUC?
4. If you are using an external device, can you provide the brand and model name of this device?
5. If the NUC is not brand new, did it work before with an AMD graphics card?
Deivid A.
ありがとうございます
1 intel ssuが出力した→townsx nuc11 pahi5.txt
2 昨年秋新品で購入
3 thunderbolt接続→https://www.aorus.com/graphics-cards/GV-N1080IXEB-8GD/Key-Features
https://www.kuroutoshikou.com/product/graphics_bord/amd/rd-rx6500xt-e4gb_sf/
m.2接続→ https://www.amazon.com/ADT-Link-External-Graphics-GTX1080ti-R43SG-TU/dp/B07XZ22HQ3
4 上記
5 NUC11→昨年秋新品購入 RADEON RX6500XT→先月新品購入、別PCで動作
GIGABYTE GPUBOX→GPUなしのBOXを中古購入、BIOS最新 GT710 1GBを入れて接続すると認識し動作する。
RX6500Xtを入れるとGPU BOX自体が認識せず
ADT-KINK m.2→pcie変換アダプタ GT710 1gbを接続すると画面出力
RX6500XTを接続すると画面出力されない
NUC本体のIRIS XEからも画面出力されないがWINDOWS自体は起動している
参考 GT710 https://www.kuroutoshikou.com/product/graphics_bord/nvidia/gf-gt710-e1gb_hs/
Hello townsx,
Thanks for the information provided. Before we continue further, I would like to try the following:
1. Set BIOS to default settings:
- Press F2 during boot to enter BIOS Setup.
- Press F9 to load defaults.
- Press F10 to save and exit BIOS Setup.
2. Perform a BIOS recovery:
- BIOS: https://www.intel.com/content/www/us/en/download/19694/bios-update-patgl357.html
- Steps: BIOS Recovery by the Power Button Menu
In the unlikely event that a BIOS update is interrupted, it’s possible the BIOS might be left in an unusable state.
Performing a BIOS Recovery can resolve this problem.
1. Plug a USB device into the USB port of the Intel NUC when it’s turned off (not in Hibernate or Sleep
mode), then power up Intel NUC.
2. Download and save the RECOVERY.zip file for your Intel NUC unit into that USB device.
3. Extract/Unzip the RECOVERY.zip file.
4. Power off your Intel NUC, keep the USB device in a USB port.
5. Press and hold down the power button for three seconds, then release it before the 4-second
shutdown override. The Power Button Menu appears.
6. Press F4 to start a BIOS Recovery.
7. Wait 2-5 minutes for the update to complete.
8. The computer will either turn off when the recovery process is complete or it will prompt you to turn off
the computer.
9. Remove the USB flash drive.
10. Restart the computer.
Our support is only provided in English. We may not be able to translate the screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
Deivid A.
Hello townsx,
I reviewed your post, please let me know if the issue was resolved, if not, do not hesitate, just reply back.
Deivid A.
ありがとう。
しかしBIOSリカバリしても状況変わりませんでした。
PCIE(m.2)に直接つなげても同じなので、thunderboltのせいではない気がします。
なぜGT710は使えてrx6500xtが使えないのか分からない
ダンプしたVBIOSアップロードしたら法的にまずいですか?
Hello townsx,
Thank you for the information provided
Deivid A.
Hello townsx,
As part of the research, I would like to confirm the following:
1. Have you updated the latest firmware version for the external video card?
2. Have you updated the latest driver version for the external video card?
3. Have you updated to the latest Thunderbolt version?
Also, You can find useful information in the following article:
- Troubleshooting Tips for eGPU on Intel® NUC
Deivid A.
1 グラフィックカードのファームウェアはNETに情報がない状態、発売されて間もない新しいものです(RADEON RX6500XT)
2 認識されずデバイスマネージャーに表示されません。よってドライバもあたりません
3 thunderbolt ドライババージョンINTELのサイトで入手できる最新 1.41.1193.0
ファームウェアはNUC11用のものでダウンロードできるものはまだ無いようです。 NVMファームウェアのバージョン 36.1
Hello townsx,
In this case, before we continue, I would like to confirm the following:
1. Were you able to try all the steps from the article?
2. Are you connecting the external video card on the front or back Thunderbolt port?
3. Have you checked with AMD support to confirm if the video card is compatible with the NUC or for specific instruction?
Deivid A.
1 Troubleshooting Tips for eGPU on Intel® NUC →NUC11のBIOSに項目がない設定があり試せないものもありました
2 前後どちらも駄目でした認識しません。thunderbolt接続でなくPCIE接続でも画面出力されない状態です
3 AMDには問い合わせていませんが、NUC11で確実に動くEGPUはありますか?
Hello townsx,
Thanks for the update, I will continue with the investigation in order to get a better response for you.
I will let you know about any updates on this matter.
Deivid A.
ありがとう。よろしくお願いします
Hello townsx,
In this case in order to have a better view of the situation, can you please share some pictures of how you have connected your video card and your NUC.
Deivid A.
Hello townsx,
Thanks for the pictures sent. I will check this configuration internally and I will let you know about any updates on this matter.
Deivid A.
Hello townsx,
Deivid A.
NUCで動作しなかった二枚のグラフィックカードは別PCで動きました
またNUCで動作しなかった二枚はBIOS自体が表示されないので、WINDOWSの問題でもないようです
じぶんが提供できる情報はこのくらいです
じぶんは技術的なことはわからないので、調べようがないですが
なんらかの機器に、規格に準拠しないイレギュラーがあるのでしょうか
別なグラフィックカードに買い替えて動けばいいのですが、三枚のうち二枚が動かずplug&playな状況といいがたく
高価でもあるので手が出しにくい状況です
ソフトウェアの更新で使えるようになれば一番いいですが
BIOS更新はこれからもあるのでしょうか
問題の切り分けとしてthunderboltで動かなかったグラフィックカードは、M.2接続でも動かなかったと報告します
thunderbolt GPUBOXの問題である可能性は低く
RADEONかNUCのどちらに問題があると思われますがじぶんにはわからないです
