When the nuc is off, it keeps the ip address.
If I want to use the ip address of the off nuc, the second computer tells me it's a duplicate ip address.
Have you ever seen this behavior ?
Who is leasing the IP addresses? Look at your router.
IP adresses is leasing by windows server 2022.
I have 1000 nuc from 5i5,7i5,8i5,10i5 and 11i5. Only 11i5 keep network connected and lock ip adresses
Check the Power Settings in the network adapter properties - should be set to "Allow the computer to turn Off this device..." (see the example).
Check in BIOS that "Wake ON LAN" is disabled as well.
Leon
I don't have this feature with i225LM
I'm not sure that Wake on LAN function is causing your problem and I don't have NUC TN to verify this, however I know that I225 Network Adapter has full Wake up support.
Open Device Manager and then right click on I225 adapter. Next click Properties and finally Power Management tab.
As I wrote in my previous post check in BIOS Power > Secondary Power Settings if Wake on LAN from S4/S5 is disabled.
Leon
I don't have Power Management tab.
Wake On LAN from S4/S5 is enable : Deep S4/S5 is unchecked. But i need Wake on lan
I did more testing today.
There must be something working in the wakeonlan even when the computer is off.
Sometimes the ping responds.
This is causing me some concern
Hello mmikka,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® NUC 11 Pro Kit NUC11TNHi5.
In this case, I would like to let you know that windows server 2022 is not on the supported operating system list for your Intel® NUC 11 Pro Kit NUC11TNHi5 as you can see here:
Does your issue also happen with Windows 10 or Windows 11?
Deivid A.
Hello mmikka,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
Hello mmikka,
I was checking your thread and see that we have not heard back from you.
I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
