Community
cancel
Showing results for
Search instead for
Did you mean:
ddavi28
nuc5cpyh boot problem- bios update - all methods fail-
hello.
what can i do? in normal boot the nuc will not display anything just restart itself, in recovery (jumper way) its just turn on and not responding,
i try 4 different usb drive with fat & fat32 system,. the nuc just read little info (i can see the usb stick flashing) and then not update.. Please Help!
Miguel_C_Intel1
Hi david456466,
Try to get into the BIOS, press and hold the power button for 3 seconds, you will see a new window with maintenance options. Select the option "F2 – Intel® Visual BIOS" press F9 then F10.
If problem continues, try with the BIOS recovery. It is necessary to copy the .BIO file in the root of the USB drive. Try with a USB 2.0 instead of 3.0. Do the test with BIOS versions 0044 and 0043.
https://downloadcenter.intel.com/product/85254/Intel-NUC-Kit-NUC5CPYH Drivers & Software
Instructions for Recovery BIOS Update
http://www.intel.com/content/www/us/en/support/boards-and-kits/000005630.html Instructions for Recovery BIOS Update for Boards and Kits
Mike C
ddavi28
Hi Mike C thanks for your replay, but as i said before:
"what can i do? in normal boot the nuc will not display anything just restart itself, in recovery (jumper way) its just turn on and not responding,
i try 4 different usb drive with fat & fat32 system,. the nuc just read little info (i can see the usb stick flashing) and then not update.. Please Help!"
"in normal boot the nuc will not display anything just restart itself" so "Try to get into the BIOS, press and hold the power button for 3 seconds, you will see a new window with maintenance options. Select the option "F2 – Intel® Visual BIOS" press F9 then F10." is not working at all
"If problem continues, try with the BIOS recovery. It is necessary to copy the .BIO file in the root of the USB drive. Try with a USB 2.0 instead of 3.0. Do the test with BIOS versions 0044 and 0043."
so this is not working too
Miguel_C_Intel1
Hi david456466,
I suggest you to contact our http://www.intel.com/p/en_US/support/contactsupport Contact Support and request a replacement.
Mike C
ddavi28
I got an answer for the computer shop and i got from them refund (too bad i cant return the memory card),
this end the respect that i had to intel NUC.
Very disappointing.
David
S.
P.S
This is the second device that i tested.
