Community
cancel
Showing results for
Search instead for
Did you mean:
RAdle1
nuc6i5syk bios update fail
I am on the BIOS version 44 and have tried all the available methods to update to the latest BIOS and they all fail. Can you advise me?
n_scott_pearson
Super User Retired Employee
First of all, review the following documents: http://www.intel.com/content/www/us/en/support/boards-and-kits/000005636.html Intel NUC BIOS Update Instructions and http://www.intel.com/content/www/us/en/support/boards-and-kits/000005532.html?wapkw=bios+recovery Intel NUC BIOS Recovery Update Instructions.
Now follow this process:
  1. Install BIOS 49 using the Recovery Method. The jumper-based method is best.
  2. Install BIOS 61 using the (normal) F7 Method.
  3. If Step 1 succeeds but Step 2 fails, then install BIOS 61 using the Recovery Method.
Notes:
  1. Use a USB 2.0 flash stick, NOT a USB 3.0 flash stick.
  2. Reformat the flash stick on a Windows-based PC. Use the FAT32 file system. DO NOT enable Quick Boot.
  3. Place only the one .BIO file on the flash stick. Do not have two different .BIO files on the flash stick.
Hope this helps,
