Intel® NUCs
Assistance in Intel® NUC products
13309 Discussions
nuc7I7bnkq has a sata port, but bios says sata port unavailable and doesn't work
gphum
I want to add a SSD to the sata port on the motherboard, but it doesn't work and the bios says sata port unavailable.  Is there a hardware or bios that can activate the port?
gphum
n_scott_pearson
Super User Retired Employee
Have you tried it with BIOS set to defaults? Use F2 to enter BIOS Setup, then use F9 to reset configuration and F10 to save it and exit.
MRoss5200
Valued Contributor I
You have a K version of the BN NUC which is the slim version of the chassis, so no SATA data/power cable is included. You need to make sure you have the correct combo cable for use on this NUC. You can't plug just any power cable in and get it to work.
Check this out:
https://www.microsatacables.com/intel-nuc-ssd-internal-22-pin-sata-replacement-cable-harness-intl-1089-22pd
gphum
Thanks I got it working with an old NUC SSD
AndrewG_Intel
Hello gphum
We are glad to know that this issue has been solved. If you need any additional information, please submit a new question as this thread will no longer being monitored since the thread has been marked as "Solved".
Andrew G.
