I don't know what to do, I have this PXE-E61: Media test failure, check cable
and can't do anything else with my nuc.
When you see this, it means that the NUC was not able to find any local resource from which to boot and is looking for a remote (LAN-based) boot server.
If this is a brand new NUC, you want to insert the media from which you will be installing your O/S and do another CTRL-ALT-DEL to initiate the process.
Hope this helps,
It is not new, it was working fine yesterday and today it wouldn't boot up. I tried the bios recovery and it still said the same thing.
Ok, you need to check the BIOS Configuration and especially the Boot Order. As well, if a device is not showing up that should be there, it may have failed...
If there is no device there every time I go to the bios configuration, what else could I do. Also would overheating be the problem too.
Please describe your system. Use part numbers where you can. What memory do you have installed? What drives do you have installed?
Well, if it was booting and working fine one day and not the next, then something has changed. You are sure you didn't change anything in BIOS Setup in between? Possibilities are:
No I didn't change anything in the Bios setup, I tried everything to make it boot and recovery but it still wouldn't.
Have you verified that the BIOS is still configured to boot from/through the Optane memory?
Can you boot from a USB flash disk formatted for booting DOS or running/installing Linux or Windows? If you can, then likely something has happened to your boot image (perhaps as a result of the Optane memory.
....S
