Intel® NUCs
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11991 Discussions
nuc7i7bnh ethernet hangs on ubuntu
Community Manager
I've just installed a new NUC 7i7BNH with ubuntu 18.04 (first installation of this NUC...) and the ethernet port hangs (drop packets ?) very often. I can see it when pinging the router where the NUC is connected to (loosing more than 35% packets over an hour). I've changed the cable/switch port but the issue is still here.
I think the bios is the last one :
Here is the information:
Intel desktop board : NUC7i7BNB
Bios version : nbkbl357.86A.0066.0724.1832
processor : Intel(r) code(tm) i7-7567U cpu @ 3.50GHz
installed with 32G RAM + 2 SSD (one sata, one M2)
Any idea ? Software ? Hardware ?
Community Manager
Hello rejo
Thank you for joining the community.
I see that you are having problems with the Ethernet connection using Intel® NUC Kit NUC7i7BNH. Allow me to help with your inquiries.
I would suggest testing the Intel® NUC with a different operating system upon reviewing the supported operating system for the Intel® NUC is Windows® 10 64 bit (https://www.intel.com/content/www/us/en/support/articles/000005628/mini-pcs.html https://www.intel.com/content/www/us/en/support/articles/000005628/mini-pcs.html). Also, you could try contacting the UBUNTU communities (https://www.ubuntu.com/community https://www.ubuntu.com/community) for a possible driver update
Hope his help.
Leonardo C.
Community Manager
Hello rejo
I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back.
Leonardo C.
Community Manager
Hello Leonardo,
Thanks for your answer.
Sorry but I had little time to test further.
I checked all the litterature I could find about about NUC and linux and did not find anything about some ethernet problem.
I also tried with wifi and everything works well.
I also have a NUC of a previous generation runnning on linux with no problem. So I'll check again the connection next week end.
Community Manager
Ok, the issue was coming from the switch.
It is quite old and it seems to have an internal failure when connecting to ports 5 to 8 (loss of packets when going from ports (1 to 4) to ports (5-8)...
So regarding the NUC, the problem is fixed.
Community Manager
Hello rejo
Thank you for the information.
I am glad to know that the problem was solved.
Leonardo C.
