Intel® NUCs
Assistance in Intel® NUC products
13320 Discussions
nuc8i7hnk dual boot in bios settings
sz3bbylA
nuc8i7hnk
I have 2 m2 hdd inside
on first I installed windows
on second I installed ubuntu and i specify install group and boot on second drive
ideea was to chose from F10 :
windows boot
ubuntu boot
after install all, on bios it disappeared uefi boot windows and apear only second drive and linux boot
windows boot disappear
both installed on uefi mode
secure boot enabled ?!?
LeonWaksman
  1. Both O.S. should be installed in UEFI mode.
  2. Install Windows 10 first, disable Fast Boot in Windows settings and disable Secure Boot in Bios. Temporary remove the SSD with Windows 10 installed.
  3. Install Ubuntu on the second SSD.
  4. Reinstall the SSD with Windows 10.
  5. Now you should see both SSD in the F10 Boot Menu.
  6. If you will read in linux forums, you may find more ideas to install both system and boot using Grub Menu. See here an example https://askubuntu.com/questions/726972/dual-boot-windows-10-and-linux-ubuntu-on-separate-hard-drives
Leon
sz3bbylA
thank you, is working
