I am building a NUC 10 music server using a fanless passive case. I will also turn off the wifi, bluetooth and use no monitor after setup. I will use a linear power supply to power the NUC for cleaner audio feeding a DAC through USB. Question, what size linear power supply would work(voltage and wattage). I know the included power supply says 19VDC and 120 watts, but would 15VDC and 6 amp linear work? Thanks
You can find the power requiremenets on page 38 and 39 of the tech spec:
https://www.intel.com/content/dam/support/us/en/documents/intel-nuc/NUC10i357FN_TechProdSpec.pdf
Doc
Topic Options
