Intel® NUCs
Assistance in Intel® NUC products
13308 Discussions
"Standard hardware security not supported" Windows 11
RolandT
I recently see this Windows 11 security warning "Standard hardware security not supported" on my Intel NUC NUC10i7FNB
Anyone an idea what is causing this? I assume W11 is unhappy about something but no indication as to what the problem is.
Alberto_R_Intel
RolandT, Thank you for posting in the Intel® Communities Support.
In reference to this scenario, we recommend to make sure that the latest BIOS version is currently installed in the Intel® NUC. Latest version is 0058:
https://www.intel.com/content/www/us/en/download/19485/bios-update-fncml357.html?wapkw=nuc10i7fnk
Instructions to update the BIOS:
https://downloadmirror.intel.com/740729/NUC-AptioV-UEFI-Firmware-BIOS-Update-Readme.pdf
To check if the Intel® NUC supports “Standard Hardware Security”, Go to "Windows Security" → "Device Security".
Windows Security displays “Your device meets the requirements for standard hardware security” if all three features are turned on:
Core isolation
Security processor
Secure boot
If any of the three is turned off, it displays “Standard hardware security not supported.” This is easily fixable by changing some settings in the UEFI (BIOS). To enter the BIOS, tap F2 several times as soon as you turn the Intel® NUC on:
Enable Intel® Virtualization Technology, Virtualization Technology, VT-x: It’s under "System Configuration". This enables Core isolation in Windows Security.
Enable VT-d. It’s: under "System Configuration". This enables Memory integrity in Windows Security.
Enable Intel® Platform Trust Technology (PTT): This enables Security processor in Windows Security.
Enable Secure Boot: For OS type, select Windows UEFI mode. This enables Secure boot in Windows Security.
Press F10 to save and exit. Now you should be able to see that Core isolation, Security processor, and Secure boot are all turned on in Windows security and the error should not appear anymore.
Here you will find additional details about Windows* Standard hardware security:
https://support.microsoft.com/en-us/windows/device-protection-in-windows-security-afa11526-de57-b1c5-599f-3a4c6a61c5e2
The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered there
Albert R.
RolandT
Thing is W11 never complained about this until very recently. The setting are all correct. I see some reports that this could be a Microsoft bug?
Alberto_R_Intel
RolandT, Thank you very much for letting us know those details.
That is correct, it seems to be this is a Microsoft bug an error related to Windows* itself based on the fact, also, that this is a feature provided by them related to Windows* directly.
So, if the settings are all correct and especially if this issue happened just recently, then the next thing to do in this case will be to get in contact directly with Microsoft Support for them to provide further technical assistance on this topic:
Albert R.
LeonWaksman
Hello @RolandT
It must be some thing in your BIOS settings (for example the Secure Boot is disabled or the UEFI Boot mode is not enabled.
I've checked on my NUC FN and there is no problem.  I've checked with BIOS 0057 and then updated BIOS to 0058.
Leon
RolandT
After another Windows11 update, I now get more info on what Windows does not like. It seems a driver that is blocking memory protection. The driver seems to be linked to a Smart Card Reader. The company states the Smart Card Reader is end of life.
n_scott_pearson
Super User Retired Employee
Are you running the latest available driver for the Genesys Card Reader? The latest is v1.1.14.0, which you can download from here: https://www.intel.com/content/www/us/en/download/19604. Manually download and install this version if not currently installed.
Hopefully this will correct the situation,
RolandT
The incompatible driver is apg8201zx64.sys this is not from the Genesis card reader but probably from an old external card reader. It seems something got not properly deleted and is now conflicting
