Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
s5000vsa server board doesn't work with 3Tb HDD
Hi! s5000vsa server board. I tryed to install HDD Seagate SV 35, ST3000VX000 3 TB, but its size recognised as 764436 MB.
I updated BIOS to http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19667&keyword=S5000vsa&lang=eng Download Center - no change.
I tryed install this update - http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21550&lang=eng&OSVersion=%0A%09%09%09... - but this update did not installed - messages like this - "....device not installed..."
Tags (1)
Highlighted
Community Manager
Re: s5000vsa server board doesn't work with 3Tb HDD
Highlighted
Valued Contributor III
Unfortunately, Embedded RAID options on this MB do not support large HDDs - http://www.intel.com/support/motherboards/server/sb/CS-032920.htm Server Products — Greater than 2TB drive support for RAID adapters and onboard server board RAID
