Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
skull canyon bios 49
Upgraded from 48 to 49 using F7 and .bio file.
Now no signal out hdmi or display port
Tried bios recovery with yellow jumper... same result
when yellow jumper is in normal position Nuc boots, powers off, boots, powers off....
when yellow jumper is in recovery position Nuc boots...
Tried swapping memory sticks...same result
Tried swapping SSD position... same result
Any help?
Highlighted
Reformatted my USB stick and tried Recovery method again...
Flashing image for Backup Recovery Block firmware ... [done]
Flashing image for Boot Block firmware ... [failed!]
Flash update failed!
Technical information: (0x8000000000000007, 0)
Recovery complete
this doesn't look good...
Highlighted
Tried 48 instead of 49 and that worked!
Anybody successfully flash KY0049.bio?
Highlighted
Community Manager
sw01: Thank you very much for joining the Intel® NUC communities.
We are sorry to hear the BIOS update was not working properly, but we are glad to hear that the NUC is working fine now. In regard to your inquiry, there are no reports stating that there is a boot problem with the Intel® NUC Kit NUC6i7KYK on BIOS 0048 or 0049. We do have the same NUC in our lab with BIOS version 0049, and it works without any problems.
The troubleshoot step we recommend to try to fix this issue, is actually what you did, which is a BIOS recovery.
Additionally, on the link below you will find the released notes for the different BIOS versions created for this NUC, in there you can verify the fixes for each version:
https://downloadmirror.intel.com/26935/eng/KY_0049_ReleaseNotes.pdf https://downloadmirror.intel.com/26935/eng/KY_0049_ReleaseNotes.pdf
I also encourage all the peers viewing this forum, that if they have any feedback or suggestions on this matter to post all the details on this thread.
Any further questions, please let me know.
Alberto R
Highlighted
Tried 49 after reformatting and that worked as well. This is on
a USB stick that was only used for BIOS updates on my NUCs.
Highlighted
Community Manager
sw01: Thank you very much for providing that information. Perfect, it is great to hear that it worked for you as well. The NUC in our lab works with no problems with that BIOS version.
Alberto R
