Community
cancel
Showing results for
Search instead for
Did you mean:
Tao_S_Intel
[solved] Screen Blink with Film Caption ON with NUC7i7BNH
Update 2018 Jun. 11
After trying firefox browser with the same film caption on, the blinking miraculously disappeared.
This issue should be an trouble with weird configuration specific under Intel HD Graphics + Chrome + 4K display.
At least I can enjoy my movie now.
BIOS: https://downloadcenter.intel.com/download/27843/NUCs-BIOS-Update-BNKBL357-86A-%3Fproduct%3D95065 Download BIOS Update [BNKBL357.86A]
GFX: https://downloadcenter.intel.com/download/27813/NUCs-Intel-HD-Graphics-Driver-for-Windows-10-for-Int... Download Intel® HD Graphics Driver for Windows® 10* for Intel® NUC Kit NUC7i3BN, NUC7i5BN, and NUC7i7BN
Thunderbolt 3 FW: https://downloadcenter.intel.com/download/27679/NUCs-Thunderbolt-3-Controller-Firmware-Update-Tool-f... Download Thunderbolt™ 3 Controller Firmware Update Tool for Intel® NUC Kits NUC7i5BN and NUC7i7BN
HDMI 2.0 FW: https://downloadcenter.intel.com/download/26609/NUCs-HDMI-2-0-Firmware-Update-Tool-for-Intel-NUC-Kit... Download HDMI 2.0 Firmware Update Tool for Intel® NUC Kit NUC7i3BN, NUC7i5BN, NUC7i7BN, NUC6CAY
Both Thunderbolt3 and HDMI has the same problem with NUC7i7BNH. however, I tried another laptop connected to the same monitor and found no problem.
with the caption on, the screen will blink a little bit while caption shows and changes.
After turned the caption off, the screen is fairly acceptable.
Community Manager
Hello Tony.Su,
Thank you for joining the Intel Community Support.
This issue usually occurs if you are using any dongle/adapter. Have you tried using other cables? How are you connecting your Intel® NUC to your monitor?
1. Please go to this link below, fill out the following information, and attach it.
https://communities.intel.com/thread/77761 https://communities.intel.com/thread/77761
2. Please attach the Intel® SSU report:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Download the utility
Run the exe and select 'Scan'
Save and include as an attachment int he Intel Community Forum
3. Run the DxDiag:
1. In the keyboard, press WinLogo key + R.
2. In the Run box please type dxdiag and hit Enter.
3. Click on Save All Information (save it in your desktop).
4. Attach the report to this thread.
Wanner G.
Tao_S_Intel
Thanks for you reply.
1. I tried the following steps
a. tried a new HDMI 2.0 cable. This screen still blinked with film caption on.
b. tried the Thunderbolt 3 port with a Thunderbolt2HDMI converter and the native HDMI port. still had blinking issue.
c. tried to connect my Apple Macbook Pro to the same cable and monitor. no screen blinking issue with film caption on.
so, it has the high chance of trouble in either Iris+ GFX650 or its driver.
2. attached SSU scanning result file as sysinfo.txt
3. attached dxdiag result file as dxdiag.txt
Community Manager
Hello Tony.Su,
Thank you for your response.
Please fill out the table and attach it.
Wanner G.
Community Manager
Hello Tony.Su,
I am writing to follow up on your inquiry.
It would be helpful to know the software/applications that you are using, too. If possible, please fill out the table to have as much information as we can about this issue.
Wanner G.
Tao_S_Intel
Thanks you for the follow-up.
As I have already given my NUC to a friend who has no 4K monitor, I am not able to reproduce the issue any more.
I remember that my NUC installed
1) Windows 10 (with the latest update)
2) Chrome (Version 67.0.3396.87 (Official Build) (64-bit))
HW configuration is mentioned as the above.
After using Firefox, the trouble disappeared.
Here is my update
Update 2018 Jun. 11
