Intel® NUCs
Support for Intel® NUC products
12748 Discussions
two different external buttons don't work sometimes?
Kannz
Hi I have two external buttons to turn on my nuc but for some reason they dont work sometimes. when I go to turn my nuc on with either button I can see the ethernet adapter's activity light flicker one time meaning its not the switch.(*I also checked if they were defective with other computers and they work fine) I have sleep hibernate and wake on lan off. None of them work. wake on lan never works at all hibernate and sleep work like 3 out of 5 times. it doesn't matter about the driver. the "old driver" and the "most recent driver" don't fix the sleep/hibernate/ect. when it doesn't work the screen will just stay black. I don't use sleep or hibernate at all anymore. the only thing I have is to turn it off. someone able tell me why the button sometimes will not turn the nuc on? (* im checking if power cycling for more than a minute does anything.)
here and the other switch is here
n_scott_pearson
Super User Retired Employee
I am not surprised by this inconsistency. Both of these switches have ATX-standard 2.54mm pin spacing, whereas the pins on the NUC boards are reduced-size 2mm versions. You could try using a conversion cable like this: https://www.amazon.com/dp/B00LSW184G
Hope this helps,
n_scott_pearson
Hope this helps,
Kannz
thank you very much that looks like it will help. this wobbly button from scamzon is just easier to push.
Kannz
got my cable today and now my power button works.
n_scott_pearson
With no inconsistencies? Excellent!
Enjoy,
