Community
cancel
Showing results for
Search instead for
Did you mean:
CPine1
unable to install any linux distribution on NUC5CPYH
I recently purchased one NUC5CPYH and I tried to install several times Linux distributions with different options without success. I am an experienced Linux user and I begin thinking that there is a hardware problem with the device.
My current hardware setup is:
- Intel NUC5CPYH with latest BIOS Version PYBSWCEL.86A.0064.2017.0815.1055
- RAM Kingston KCP3L16SS8/4 4GB (1600 MHz SODIMM, DDR3L, 1.35 V, CL11, 204 pins): bought new for this device
- SSD Patriot Torqx 2 32GB SSD: previouly used for another PC but working without error
Tests I performed:
1. I tested RAM for 10 hours with memtest56+, no error appeared.
2. Attempts to install Linux in Legacy mode with BIOS setting of OpenELEC defined in https://www.intel.com/content/www/us/en/support/articles/000022600/mini-pcs.html BIOS Changes Required Before Operating System Installation ()
- Arch Linux 2017.11.01 with kernel 4.13.9
- Result: Failed to boot
- Output:
intel_pstate: Intel P-state driver intializing
ledtrig-cpu: registered to indicate activity on CPUs
coprocessor segment overrun: 000
- Arch Linux 2017.12.01 with Kernel 4.13.12
- Output:
vlv2_plat_clk vlv2_plat_clk: vlv2_plat_clk initialized
----[ cut here ]----
WARNING: CPU: 0 PID: 0 at kernel/sched/clock.c:391 sched_clock_tick+0x4e/0x60
- Arch Linux 2018.01.01 with Kernel 4.14.9
intel_pstate: Intel P-state driver initializing
copreocessor segment overun: 0000 [# 1] PREEMPT SMP
3. Attempts to install Linux in UEFI mode with BIOS setting of Windows/Ubuntu defined in https://www.intel.com/content/www/us/en/support/articles/000022600/mini-pcs.html BIOS Changes Required Before Operating System Installation ()
- Lubuntu 16.04.03 LTS 64-bit
- Output:
RIP: 0033:0x7fde38bc0499
RSP: 002b:00007ffd38be28e8 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
RAX ... RBX: ... RCX: ...
Code: 25 28 00 00 00 75 70 48 83 c4 ....
- Output:
- Output:
Uhhuh. NMI receved for unk
Do you have a strange power savi
Dazed and confused, but trying to continue
- Arch Linux 2017.12.01 with Kernel 4.13.12 with BIOS's Intel Dynamic Power Technology to OFF
- Output:
---[ end trace 70b1f1a6a5192163 ]---
kernel panic - not syncing: Attempted to kill the idle task!
Kernel Offset: 0x3a000000 from 0xffffffff81000000 (relocation range: ...)
---[ end kernel panic - not syncing: Attempted to kill the idle task!
Please, could you tell me how I could proceed to install Linux in the device or if I should return the device??
Thanks in advance,
Christian
Tags (1)
Community Manager
chrpinedo: Thank you very much for contacting the Intel® NUC communities. We will do our best to assist you with this scenario.
In regard to your inquiry, Intel does not test and validate Intel® NUC on Linux; however we know that a lot of NUC owners are using it successfully on many different Linux distros.
Intel suggests for you to check your Linux distro's website and forums for peer assistance with this issue at:
http://www.linuxforums.org/forum/ http://www.linuxforums.org/forum/
Any further questions, please let me know.
Alberto R
