Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13511 Discussions
unable to install win10 on nuc10i3fnh, installed gigabyte NVMe 128 ssd and 8 GB ram. nuc can see to ssd and ram, boot priority missing for ssd. when installing win10 I get as far as the install button, after that a message "no device drivers where found"
dhowa7
I've put all drivers from intel site on the pendrive both zipped and un-zipped
LeonWaksman
  1. Please prepare your installation media (you need 8GB – 32GB USB stick), using Microsoft Media Creation Tool .
  2. Your bios should be set to default settings. Enter bios (press F2 during boot) and then press F9 (Y) to set defaults and F10 (Y) to save settings and exit.
  3. With the installation media inserted into rear USB slot, power ON your NUC and repeatably press F10 to get Boot Menu.
  4. In this menu, choose UEFI option of you Installation media.
  5. Follow this tutorial to continue with installation
  6. In para. 7 you may enter Product Key from the Microsoft Distribution you bought.
  7. Skip on para. 12 and continue in para. 13. Important, do not format drive where you want to install Windows, rather delete all existing partitions from this drive, till you see one unallocated space.
  8. Press Next and continue with the installation.
Leon
dhowa7
thanks for getting back to me
it was the ssd, it needed formatting. not had to manually format a drive in over fifteen years
LeonWaksman
I've to say that this is very strange to me that you needed format the SSD. I've installed Windows 10 may times and never had to format drive after deleted all existing partitions (as described in para. 7, in post above). Any way, I'm glad that your NUC works now.
Leon
dhowa7
it was strange to me as well, i would get to the windows install page, it would let you click install, but that was it, it wouldn't go any further
thanks again
dave
