Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13484 Discussions
using intel NUC dn2820fyk without case
dendenmushi
Hello. I wanted to use intel NUC DN2820FYK 
in eurobot competition, but there is a weight restrictions. Therefore I'm thinkng to remove a case that weights almost half of overall, and I wanted to know : can I remove the case and what problems I would probably struggle? I see that wifi-module is attached to the case with metal conductor (I leave picture here). So would I have a connection problems without the metal case and which solution you may suggest if so?
Thank you for your feedback, leaving photo of connection with case here
n_scott_pearson
Super User Retired Employee
Running the board outside of the chassis is no issue. If you want to also use wireless, I suggest you replace the antennas; the internal antennas are not meant to be used detached from the chassis. Alternatively, you can use a kit like this: https://www.amazon.com/dp/B01GMBUS8O
Hope this helps,
