Intel® NUCs
12098 Discussions
using nuc8i7hnk problem with samsung TV After update the drivers, The tv few times in hour turn off/on for few seconds...
AElba
and sometime don't turn on, have to restart the nuc8...
more, if I turn on the nuc8 when the screen is off, can't login untill restart the computer.
please refer me to the last drivers page to solve the problem
Amy_C_Intel1
Hello AElba, Thank you for posting on the Intel® Communities. You can find the latest drivers for this unit here: https://downloadcenter.intel.com/product/126141/Intel-NUC-Kit-NUC8i7HNK I recommend you to update BIOS Update [HNKBLi70.86A], Intel® Chipset Device Software for Windows® and then the graphics driver. Amy C Intel Customer Support Technician Under Contract to Intel Corporation
Amy_C_Intel1
If you need further assistance let us know. Amy C Intel Customer Support Technician Under Contract to Intel Corporation
AElba
Thanks for quick response.
try to update the bios and get message tha already have the last version.
I also setup the chipset from the link and , after restart the problem stil exist...
Alon
Amy_C_Intel1
Which drivers did you update before the issue started? Let me know the versions. Amy C Intel Customer Support Technician Under Contract to Intel Corporation
AElba
before the issue started the samsung tv was not reconized as proper driver and I use the tv like defualt screen.
  1. Then, I go to this link: https://www.intel.com/content/www/us/en/support/intel-driver-support-assistant.html
  2. And instal all drivers suggested.
  3. The tv recognized as proper driver start to get HD + the tv sound is back
  4. but, new issue, everery few minutes the tv has black screen for few seconds and sometimes it stay like that until restart the computer.
  5. today i do more the 10 restart a day, it's very frustrating.
I prefer to remove the graphics drivers and go back to non hd without sound.
AElba
Attached the Detailed report from the support assistant
AElba
after removed the Intel HD graphics driver, the screen stop turn off to black screen,
still see hd resolution, but didn't hear voice from tv.
eventually I can work now : ) woithout need to restart 10 times a day.
when will be a better HD graphics driver, I will try it.
Amy_C_Intel1
Thank you for that information. Glad to hear you can work now! Yes, you can always check https://downloadcenter.intel.com/ for future driver releases. Amy C Intel Customer Support Technician Under Contract to Intel Corporation
