Hi
I am interested in the vcust UQI commands for my nuc (NUC8i3BEK) More specific the bios setting of "Wake system from S5" - setting a specific day and time to wake up. The vcust manual says:
"UQI and value options should be from a report of the current BIOS."
but how do you generate that report?
Dan
Hello DPage7,
Thank you for submitting your question on this Intel® Community.
To better assist you, we would like to have the following information:
Could you please let us know why you would like to modify this setting?
Wanner G.
A Contingent Worker at Intel
Hi Wanner
Our customers do not have access to the nuc directly. We need the ability to change this setting dynamically and remotely. The only way to change this now , is to physically be on location with a keyboard hooked up to the nuc which complicates the process :)
Dan
Hello DPage7,
Thank you for your response.
We will look into this issue, and update this thread as soon as possible.
Wanner G.
Hello DPage7,
We would like to update this thread.
To Enable and set up Wake System from S5 setting in BIOS via VCUST, please use the following:
VCUSTW64 -CONFIG -UQI=xxxx -VALUE=y
where [xxxx] is the UQI value and [y] is the variable.
To Enable or Disable Wake System from S5:
UQI - 07e3
0 : Disable (default)
1 : Enable
(example of the command to enable Wake System from S5:
VCUSTW64 -CONFIG -UQI=07e3 -VALUE=1)
To set up the recurrence:
Select Daily/Weekly/Monthly to wake the system. UQI = 091d
0 : Daily
1 : Weekly
2 : Monthly (default)
Sunday: UQI = 091e
If enabled, system will wake at the selected time via RTC alarm on every Sunday.
1 : Enable
Monday: UQI = 091f
If enabled, system will wake at the selected time via RTC alarm on every Monday.
1 : Enable
Tuesday: UQI = 0920
If enabled, system will wake at the selected time via RTC alarm on every Tuesday.
1 : Enable
Wednesday: UQI = 0921
If enabled, system will wake at the selected time via RTC alarm on every Wednesday.
1 : Enable
Thursday: UQI = 0922
If enabled, system will wake at the selected time via RTC alarm on every Thursday.
1 : Enable
Friday: UQI = 0923
If enabled, system will wake at the selected time via RTC alarm on every Friday.
1 : Enable
Saturday: UQI = 0924
If enabled, system will wake at the selected time via RTC alarm on every Saturday.
1 : Enable
Wakeup Date: UQI = 010c
Select day of each month to wake the system. Select 0 for daily wakeup.
Default Value is 1.
Minimum Value : 0
Maximum Value : 31
Wakeup Hour: UQI = 010e
Select wakeup hour in 24-hour format. For example, 15 means 3 PM.
Default Value is 0.
Minimum Value : 0
Maximum Value : 23
Wakeup Minute: UQI = 010f
Select wakeup minute.
Default Value is 0.
Minimum Value : 0
Maximum Value : 59
Wakeup Second: UQI = 010a
Select wakeup second.
Default Value is 0.
Minimum Value : 0
Maximum Value : 59
It is worth mentioning that these UQI values are only for Intel® NUC Kit NUC8i3BEK. If you need UQI values for other Intel® NUC products, please let us know.
Wanner G.
Thanks, It works :) Merry Christmas
Dan
