Intel® NUCs
12312 Discussions
wifi very slow - NUC8i3BEH
hendri-hendri
Hi
This month, I just purchased NUCi3BEH - i38140U CPU @ 2.10GHz, RAM 16GB
and I just aware that my wifi is very slow
I tried to do speedtest, only get around 2-4Mpbs , I tried at the same spot, using macbook, I got 15Mpbs
I've tried many tweaks found on google, update driver, some network adapter setting, etc, but no improvement at all
Can anyone share the solution please
thx
AlHill
So we can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (look at the instructions under the reply window).
Doc
hendri-hendri
As per attached
thx
Alberto_Sykes
Hello hendri-hendri, Thank you for posting in the Intel® Communities Support.
I just wanted to check if the problem with the Intel® Wireless connection still persists and if you need further assistance on this matter?
Albert R.
A Contingent Worker at Intel
Alberto_Sykes
Hello hendri-hendri, Since I have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
