Hello I have a last gen nuc. I'm having a problem with drivers. I'm using windows 11 22000.652 at the moment. could someone point me to the correct drivers for windows 10 or 11? My sound driver updated through windows and now I have no sound. after Realtek - Extension - 1.0.8950.1 update and Realtek Semiconductor Corp. - Extension - 6.0.8950.1. i dont know how to remove the updates.
EDIT: sorry forgot to add the information
Operating System: Microsoft Windows 11 Pro(10.0.22000 Build 22000)
Physical Memory (Installed): 32 GB
Processor: Intel(R) Core(TM) i3-10110U CPU @ 2.10GHz
System Type: x64-based PC
Total Installed Updates: 19 Updates - See Detailed View for more information
Display Adapter(s): Intel(R) UHD Graphics 30.0.101.1660
System Manufacturer: Intel Corporation
System Model: NUC10i3FNB
Network Adapter(s): Intel(R) Ethernet Connection (10) I219-V 12.18.9.23
VirtualBox Host-Only Ethernet Adapter 6.1.34.636
Disk(s): Samsung SSD 850 PRO 256GB 187.46 GB (available) 10.0.22000.1
Samsung SSD 980 PRO 500GB 364.87 GB (available) 10.0.22000.1
By internal I mean internal, but you can use them to route to a front panel if you wish.
There is not enough information provided with that item to tell if that connector has the right pitch (you need 1.25mm pitch, not 2mm).
As I said, Micro SATA Cables (and GORITE, the manufacturer behind them) is the best place to get the correct cables. In addition to the lids, they have a complete selection of cables. They also sell through Amazon and I just did a search to see if this cable is orderable there. Sure enough, here it is: https://www.amazon.com/dp/B07N2N8V12.
Hope this helps,
Hi @Kannz
1. The first driver you have to install is the Chipset Device Software. After Downloading and installing this driver reboot your NUC.
2. Only now, you may download and install all other drivers.
3. If you don't fill safe to manually download and install drivers, after manually installing the Chipset Device Software, download and install the Intel Driver & Support Assistant and use it for the driver update.
Leon
a couple of the current drivers aren't able to be downloaded? the thunderbolt driver and the realtek audio driver?
You are right. There is a problem in the Download Site. The Thunderbolt DCH driver and the latest Realtek Audio driver can't be downloaded. Wait for Intel Agent for answer.
Leon
cool. thank you very much. I now have the two drivers I was wanting I think.
one other thing I was wondering about the lan driver 12.18.9.23 does it allow wake on packet? I don't see an option in the driver advanced settings area. two missing spots that say no description though?
Hello Jamesdemar,
Please confirm you are trying to download the drivers from these links:
- Thunderbolt DCH: https://www.intel.com/content/www/us/en/download/19402/thunderbolt-3-and-4-dch-driver-for-windows-10...
- Realtek: https://www.intel.com/content/www/us/en/download/19481/realtek-high-definition-audio-driver-for-wind...
As well, are you getting any error while trying to download? Or is it an issue with the Download Center? If there is any error, please provide a screenshot/ picture.
Steven G.
Hello Leon,
Thank you for confirming the issue with the Download Center is now solved.
@Kannz Please let me know if you do not have the issue anymore or if you have any additional concerns I can help you with.
Steven G.
uh my reply was farther up. not sure why.
earlier reply:
Hello Kannz,
Thank you for your response.
The Intel® Ethernet Connection I219-V does support Wake on LAN (WOL). Make sure it is enabled in BIOS:
- Press F2 during boot to enter BIOS Setup.
- Select the Power menu.
- Within Secondary Power Settings check to make sure Wake-on-LAN from S4/S5 is set to: Power On - Normal Boot (this is the default setting).
- Press F10 to save and exit the BIOS Setup.
As well, make sure to enable the "Allow this device to wake the computer" and “Only allow a magic packet to wake the computer” options. Even though the option is not present in Advanced settings, WOL should still work fine.
Let me know if you have any other concerns.
Steven G.
Thank you I'll try this out when I get the chance.
I have another question. Is there a problem with the graphics driver? having a few bugs I think not related to hardware. what is the recommended graphics driver version to use? I'm using the most recent version 30.0.101.1660. sometimes my screen goes blank and also sleep mode doesn't work most of the time.
EDIT: thank you Alhill. I'll install that one. not sure why I wasn't able to find the newer driver.
@Kannz The most recent version is 1960:
https://www.intel.com/content/www/us/en/download/19344/intel-graphics-windows-dch-drivers.html
@Kannz "Is there a problem with the graphics driver?"
Sorry, but I cannot resist - Does the bear live in the woods?<G>
Hello Kannz,
Are you getting the blank screen when doing a task in specific (gaming, watching videos, editing, etc.)?
Was the latest driver version 30.101.1960 able to solve the issues?
Steven G.
Since I updated the new driver it seems the screen blanking has stopped so it may of just been a badly installed driver.
could you tell me what the two white 4pin sockets are on the nuc board? I know it says usb but what is it used for? front panel? what adapter would I need for this?
Those are headers for internal USB 2.0 ports. Micro SATA Cables offers a whole slew of replacement lids for the FN NUCs that make use of these ports to support various capabilities.
thank you for the reply.
by internal you mean they would be for front panel? what cable would I need for that? I'm not using the original case I have it in a akasa turing fx so a case top wouldn't really help. I would be looking for just a cable out of a port in my case right off the nuc board.
EDIT: would this work? amazonlink
Hope this helps,
Cool. thank you for the help.
We're glad to know the information helped. Hopefully, it will help other community members.
Since the thread is now solved, we will close it. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
oops I accidently hit the solved button. My screen going black is still happening. is there a recommended old driver that works? sigh..
