Intel® Optane™ Memory
1345 Discussions
Не работает intel optane
АДвое
Установил в ноутбук acer nitro 5 память intel optane 16gb и программа выдает ошибку, биос работает в uefi. Обновил до последней версии.
https://www.mvideo.ru/products/noutbuk-acer-an515-51-571w-nh-q2qer-008-30039128 Ошибка
Hello death09,
Thank you for contacting Intel® Technical Support.
As we understand, you need assistance with your Intel® Optane™ Memory. If we infer correctly, to begin diagnosis and consequent troubleshooting that could take us to a resolution, and we would appreciate if you could, please, reply to this post with the following, important, basic information:
We will be looking forward to your reply.
Josh B.
Hello death09,
Thank you for having contacted Intel Technical Support.
We have not heard from you since our last communication and we would like to know if you need further assistance or if we can close this case?
Important note: Should further assistance or clarification be required, we will greatly appreciate if you reply to this post instead of writing a new one unless your inquiry is completely unrelated. This way we will prevent generating a duplicate post and we will not lose the train of thought.
Josh B.
