Intel® Optane™ Memory
1391 Discussions
Ноутбук не видит SSD диск
NAZAR
В ноутбук lenovo ideapad 330-17ICH(model: 81FL) вставляю SSDSCKJW180H6 , а он его не видит, не через BIOS, не через управление дискам. Как это исправить?​
LeonWaksman
  1. It is new SSD that you have installed? If yes, remove the SSD and reset it again the the M.2 slot. It should be fastened in its place with a fastening screw.
  2. Check in Bios, that the PCI M.2 slot is enabled.
Leon
LeonWaksman
Leon
n_scott_pearson
Also, are you sure that this M.2 socket provides SATA support?
