You need to write this message, to give us possibility to translate it. The translator is not working on images.
Leon
I can see that the Optane application generated an error code: 0xA008002D . This error is generated in attempt of enabling Optane Memory. The ennoblement failed because your Bios is not supporting Optane Memory, or System Bios is set to Legacy Mode. see the error code explanation: https://www.intel.co.kr/content/www/kr/ko/support/articles/000024113/memory-and-storage/intel-optane-memory.html
- You should confirm that your system supports Optane Memory. If yes, take care to update Bios to the latest version.
- UEFI is required for Intel Optane memory support. If the Boot mode in the BIOS is set to Legacy, or CSM enabled, enabling system acceleration will not work.
- When an operating system installation occurs while in Legacy mode the partition structure is MBR, which is not supported. A GPT partition structure is required, which is created when the operating system is installed when in UEFI mode.
- If your sytem was installed in Legacy mode, please read the tutorial how to convert it to UEFI mode https://www.intel.com/content/www/us/en/support/articles/000024558/memory-and-storage/intel-optane-memory.html (this is link in Korean: https://www.intel.co.kr/content/www/kr/ko/support/articles/000024558/memory-and-storage/intel-optane-memory.html)
Leon
