Community
cancel
Showing results for
Search instead for
Did you mean:
PRoes
Disabled my 32GB Optane, system restarted and is now unbootable. Unable to recover. Optane only recognized as a ~3GB device with no partitions. The 2TB HD it was paired with is not recognized by system at all.
Jump to solution
The title covers the basics.
I tried using testdisk but it also just sees the Optane as a ~3GB volume with no partitions. The 2TB HD doesn't even show up at all, anywhere - not in Windows, BIOS, or Testdisk.
Any ideas? I want to try and recover data from the HD if possible. I've since upgraded to a 2TB SSD and don't plan on re-enabling Optane due to this massive failure.
LeonWaksman
Did you changed the SATA mode in BIOS from "Intel RST..." to AHCI?
Leon
LeonWaksman
Leon
