Intel® Optane™ Memory
1392 Discussions
I I would like to know INTEL® SSD 750 SERIES (1.2TB, 1/2 Height PCIe 3.0, 20nm, MLC disk can be used in Quanta server D51B-2U (dual 10G LoM).
SRaju2
One vendor was saying its not compatible, so wanted to confirm.
JosafathB_Intel
Hello SRaju2, Thank you for contacting Intel® Memory & Storage Support. As we understand, you need assistance with the Intel® SSD 750 Series, if we inferred correctly, please review the information below: 1. The Intel® SSD 750 Series is a consumer/enthusiast SSD meaning that is not designed to be used on a Datacenter/Server environment. https://www.intel.com/content/www/us/en/products/memory-storage/solid-state-drives/consumer-ssds.html 2. As mentioned the Intel® SSD 750 Series is a consumer SSD and the list of tested and validated hardware (please notice that the validated motherboards are consumer motherboards) can be found in the following link: http://compatibleproducts.intel.com/ProductDetails?activeModule=Memory%20and%20Storage# 3. As mentioned by your distributor the Intel® SSD 750 Series is not validated to be used on a server environment, exposing this product to a data center workload will wear out this drive faster than expected and may void your product warranty. We advise you to check with your server original equipment manufacturer (OEM) for their list of compatible and tested hardware to avoid incompatibility issues. Please, let us know if you need further assistance or if we can close this case. We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
SRaju2
Hi Josh, Really appreciate your kind response on this. Do you have any 1.2 TB NVMe SSD suggestions from Intel for Datacenter servers. I have already tried to reach OEM of our server and unfortunately I didn’t get response yet. It would be really grateful if you can help us to identify the right NVMe SSD for our server. Thanks, SasiKumar +60176917259
JosafathB_Intel
Hello SRaju2, Thank you for your reply. We advise you to check the following link in order to get further information regarding our “Intel® SSDs” solutions that may fit your needs. We strongly advise you to contact your OEM before purchasing any of our products in order to check for validation and compatibility. https://ark.intel.com/content/www/us/en/ark/search/featurefilter.html?productType=35125&3_DriveCapacity-Min=1200&3_DriveCapacity-Max=8000&1_Filter-Family=83425&0_StatusCodeText1=3,4&2_SSDInterface=PCIe%20NVMe%203.1%20x4 If you need further assistance please do not hesitate to contact us. Best regards, Josh B. Intel Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello SRaju2, Thank you for having contacted Intel® Memory & Storage Support. This is just a friendly reminder that your case remains open. Should you need our technical assistance please do not hesitate to contact us back. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
SRaju2
Thanks for the details. Please proceed to close the case. Thanks, SasiKumar | Storage&Backup Tower | IT Service Delivery Management | Group IT - Malaysia Airlines | Mobile: +60176917259
JosafathB_Intel
Hello SRaju2, Thank you for your reply. As per your consent, this case is now close if you need further assistance please do not hesitate to contact us again. Best regards, Josh B. Intel Customer Support Technician Under Contract to Intel Corporation
