Intel® Optane™ Memory
I can't use my intel optane
MrZacki30
Hi, this happened when I formatted my entire hard drive at a low level since it had bad sectors and that, and I think that when I create a bootable USB, I inadvertently format the Intel Optane memory and it does not recognize it.
any solution?
AlHill
Did you disable the optane+hdd pair before your formatting?
Did you add back the optane partition at the end of the HDD?
So we can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Doc
