Intel® Optane™ Memory
1392 Discussions
Is it possible to use OptaneMemory acceleration in pxe boot environment?
동김3
Case.1
1 PC / 1 OS / Rollback
Case.2
1 PC / Multi OS / Rollback
Case.3
1 PC / 1 OS / Write back
Case.4
1 PC / Multi OS / Write back
Hello dongmai1,
Thanks for posting in our communities. We understand that you would like to know if Intel® Optane™ memory system acceleration can work on a PXE boot environment.
We haven't test this scenario and therefore can't confirm if it'll work. However, Intel® Optane™ memory requires a compatible physical boot drive to enable system acceleration, which is either not always present or required with PXE boot. Based on those facts, it is quite possible the configuration won't work.
You can learn more about Intel Optane Memory here:
- https://www.intel.com/content/www/us/en/support/articles/000023994/memory-and-storage/intel-optane-memory.html Overview and Requirements for Intel® Optane™ Memory
- https://www.intel.com/content/www/us/en/support/articles/000024018/memory-and-storage/intel-optane-memory.html Frequently Asked Questions for Intel® Optane™ Memory
Please let us know if there's anything else we can do for you.
EDIT: The thread has been moved to .
Eugenio F.
