Intel® Optane™ Memory
1343 Discussions
New Intel Optane SSD 905P Series AIC PCIe want to replace current OS Intel SSD drive. Can a partition backup be used in this process?
JAnde47
MSI Z370 Octane compliant Motherboard.  I want to replace my Intel SSD that has WIN 10 64 OS on  it.  Can I use the current image of this drive to swap to the Octane memory? ​Any special procedure out of the norm to do this?
LeonWaksman
  1. You should first disable Optane memory before taking backup of your disk.
  2. After replacing the SSDs, restore backup image to the new SSD and enable Optane Memory again.
  3. There is Intel Data Migration Software for cloning data from old drive to Intel SSD: https://downloadcenter.intel.com/download/27960/Intel-Data-Migration-Software?v=t
  4. More explanations here: https://www.intel.com/content/www/us/en/support/articles/000006082/memory-and-storage.html
Leon
JAnde47
​I plan on backing up C: GPT UEFI with Acronis and Macrium.  Shutdown and install card.  Boot with recovery software and recover to Octane drive.  Boot to BIOS and turn on Octane.  Boot normanl start up.
Or would I need to turn on Octane in BIOS before recovery?
LeonWaksman
Leon
JAnde47
​Thanks for the heads up.....why does this answer scare me...lol
JosafathB_Intel
Hello JAnde47, Thank you for having contacted Intel® Technical Support. I was reviewing your community post and we would like to know if you need further assistance or if we can close this case. We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello JAnde47, Thank you for having contacted Intel® Memory & Storage Support. This is just a friendly reminder that your case remains open. Should you need our technical assistance please do not hesitate to contact us back. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello JAnde47, Thank you for having contacted Intel® Memory & Storage Support. This post is to let you know that we will proceed to close this case. Should you need our technical assistance please do not hesitate to contact us back. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
