Hace poco cambie mi GPU y mi MB, en este caso la MB que tenia era una H270 y la cambie por una Z270. Al momento de instalar la optane me salia el error de que ningún equipo de almacenamiento era compatible con Optane cuando antes de cambiar la MB no detectaba problemas. Luego descargue "Tecnología de almacenamiento Intel Rapid" y me sale en la ventana de Memoria Intel Optane lo siguiente:
-Estado de la memoria Intel Optane: desactivada
-Parece que el sistema esta listo para la memoria Optane, pero no se han detectado módulos de memoria Intel Optane en el equipo. Instale un modulo compatible. Visite intel.com/support/optane-memory para obtener mas información (así es como llegue aquí).
El modo Optane esta activado en la BIOS y con el modo RAID activado. Tengo un buen tiempo con este problema y este es mi ultimo recurso :C.
Hello Josh B.
Thanks for answer my post so fast.
Here are the things you asked me:
•A screenshot of the “Disk Management” of windows showing all your HDDs and partitions (this to have a better view on how your HDD is detected by the OS)
• A screenshot of the error that you are receiving.
• We will like to know if you disable the Optane acceleration before moving your Optane from the previous motherboard to the new one.
-I didnt disable the optane acceleration before moving it to the new MB :c.
• We will like to know if you have tried to clean your Optane memory information by formatting the memory from your OS.
We will be looking forward to your reply including this information.
-I was looking for a way to clean the Optane memory information but I cant find it.
The file of SSU logs:
Hello Josh B.
Thanks for you reply :D.
I was looking in my BIOS for the "Intel® Rapid Storage Technology" and I find this:
*This is the ez mode*
*This is the Advanced mode**This is the Advanced option*
*This is the "Intel® Rapid Storage Technology" option*
As you can see I cant see my Intel Optane memory :/.
Im trying everything and I really appreciate all your help.
Thank you so much
pdta: My new MB is a z270
I still have problems with my intel optane :/
