Intel® Optane™ Memory
1391 Discussions
Optane memory module works on aspire e5 575g
bdiaz
I have aspire e5 575g 54vr
https://www.acer.com/ac/en/US/content/support-product/6737?b=1 https://www.acer.com/ac/en/US/content/support-product/6737?b=1
slot m.2 and i5 7th gen
i don't know if s compatible with optane module cache with bios upgrade, any help?
in the bios upgrades are this
InsydeH2O
1. Update EC to 1.7
Date: 2016/05/20
Version: 1.04
1. Improve system performance.
Date: 2016/08/23
Version: 1.12
1.Update Microcode to 0x38. 2.Update brightness table. 3.Add PBA function.
Date: 2016/10/19
Version: 1.15
1.Update EC to v2.2.
Date: 2016/11/24
Version: 1.18
1. Add N16P-GT1 graphic support.
Date: 2016/12/23
Version: 1.20
1. Update memory rc code.
Date: 2017/02/20
Version: 1.23
1. Update ME to 11.6.20.1221 for some sku
Date: 2017/03/27
Version: 1.25
1. Update following microcode
M36506E3_000000B9_000000BA.TXT
MC0406E3_000000B9_000000BA.TXT
2. Fix S3 wake up, USB BT yellow mark, CCD not work, some port fail.
3. Update EC to v2.3.
Date: 2017/06/26
Version: 1.27
1. Update GOP to 1066 and vbios to 1051.
2. Update EC to v1.10.
3. Update Microcode.
Date: 2017/09/27
Version: 1.29
I have version 1.23 just now
bdiaz
on this article
http://www.tomshardware.com/news/intel-optane-3d-xpoint-motherboard,33398.html Intel: No 200-Series Mobile Chipsets, Optane Memory Support Comes To 100-Series Chipset Instead
2Intel® Optane™ Memory and its logo denote a platform feature made up of individual components and not solely a single small factor solid state drive or a memory media. A system that is Intel® Optane™ memory ready includes: an 7th Gen Intel® Core™ or Xeon® E3 v6 processor1, an Intel® 200 series2 or 100/C230 series3 (HM175, QM175, or CM238) chipset, M.2 type 2280-S1-B-M or 2242-S1-B-M connector on a PCH Remapped PCIe* Controller and Lanes in a x2 or x4 configuration with B-M keys that meet NVMe Spec 1.1 and System BIOS that supports the RST 15.5 driver.
  1. Support limited to Intel® S-, H-, and U-series processors.
  2. Only supported on 7th Gen Intel® Core™ or Xeon® E3 v6 S-series processors.
  3. Only supported on 7th Gen Intel® Core™ or Xeon® E3 v6 H-series processors.
Hello stiven680,
Thank you for your interest in the Intel® Optane™ Memory.
I understand you would like to find out if your Acer* Aspire E5'575G laptop is capable of supporting Intel® Optane™ Memory. Third-party compatibility inquiries are handled by the manufacturer's technical support team, but I may provide some insight.
Please keep in mind that aside from the hardware requirements, your computer's UEFI must also be Optane™ Memory-ready.
As you pointed out in the second post, the hardware requirements are as follows:
  • M.2 PCIe NVMe 3.0 x2 port
  • 7th Gen Intel® Core processor
  • 200 Series Chipset
For some systems this means that it can be supported after a BIOS update, for others it means that despite hardware requirements Optane™ may never be supported ( none of the updates that you shared in the original post mention anything about Optane™ Memory compatibility, but that is not conclusive).
According to the information you provided, it seems that aside from the 200 Series chipset, your system meets the base requirements. I reviewed the product specifications that are available online and by the looks of it, your computer meets some of the base requirements (the chipset information should be provided by Acer*).
As I previously mentioned, the best way to confirm the compatibility of your system would be to ask your computer manufacturer if this model is "Intel® Optane™ Memory-ready". If they're unable to provide an answer, then it's more than likely that it will not support this technology. In order to receive the corresponding compatibility confirmation, please check the manufacturer's link: https://www.acer.com/ac/en/US/content/support https://www.acer.com/ac/en/US/content/support
Andres V.
bdiaz
thanks, i go to technical support to talk about this, and i see various models with chipset series 100 that are compatibles with optane, as asus vivo book 15 or samsung oddysey
i think is possible
