La motherboard es un modelo 8486 v.72.23. Ligada a un procesador i5-8250U
Me preocupa que la alimentación activa sea diferente entre modelos, y no sé si esa diferencia para la computadora signifique algo
You may safely upgrade the Optane Memory to 32GB model. 0.5W difference in power consumption will not affect the Power Supply. But do not forget, before removing the 16GB module, you have to disable the engagement first. Only after the Optane acceleration is disabled, you may replace it by the new 32GB module and enable the acceleration again.
Leon
Leon
Thank you for your swift answer @LeonWaksman !
Your comments make me feel more confident to do the change.
