Intel® Optane™ Memory
1391 Discussions
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED iaStorAC.sys After updates and forums and i still get BSOD
GTomb1
I have an older Dell XPS that has been a trusty work horse.
Recently it done some updates last week and seemed fine. Yesterday i started to get BSOD whenever i unplug the power lead.
The error is --
iaStorAC.sys
I have followed the forums to try and find a solution and all point to the INTEL RST driver update. I fount the latest driver and updated it.
Still as i unplug the power lead i get the BSOD.
Can someone help, i'm not a PC guru but know enough to generally get me by.
n_scott_pearson
Simple things first. Are you actually using​ RAID or Optane? If not, just uninstall the Intel RST package (it's unnecessary).
GTomb1
I only have 1 hard drive and dont believe i use raid or Optane. I searched for Intel RST and could not find it before i done any updates.
n_scott_pearson
There should be an entry for it in Apps & Features -- or did you upgrade from Windows 7/8/8.1 to Windows 10?
GTomb1
Yes this PC started life as an 8, then to 8.1 then 10.
n_scott_pearson
Ok, this is starting to make sense. You system is probably old enough that the RST support is only through legacy drivers and they are likely not handling something Windows 10'ish.
I need more information about your system to help diagnose this. Please download and run the Intel System Support Utility for Windows and then save the report generated to a text file. Then, using the paperclip icon below the edit window, upload and attach this file to a response post.
GTomb1
I really appreciate your help, Thank you
IaMataSula
Hi there Scott, I saw that you had helped someone else with their issues, and I too have been receiving such errors but it's a new laptop, 2020, with no raid configurations, same windows OEM installation.
I have attached the report that you had asked to dissect the problem and also another crash report that I have. if you have any suggestions or help, please let me know, I would be happy to answer any other questions you may have.
Thank you!
n_scott_pearson
Are you using RAID? Are you using Optane? If the answer to both questions is No, then uninstall Intel RST. It has no value proposition outside of these two usage models. Once upon a time, it offered improved performance (versus the MS Storage driver), but this is no longer the case.
Hope this helps,
GTomb1
I have spent the last 11 hours backing up everything to portable hard drives
n_scott_pearson
Good. I am not seeing anything obviously wrong in the report. I would have to do some investigation in order to figure out how to hack out the RST content. It would be better - from a whole bunch of perspectives - if you disabled RAID (i.e. set SATA Mode parameter to AHCI in BIOS Setup) and then did a from-scratch reinstall of Windows 10. This won't be the only place where you are carrying bloat from the Windows upgrade processes (I shudder to think what your Registry looks like). [Aside: I think folks should do this once a year; it will usually speed their systems up significantly.]
Somewhere I have scripted instructions for doing this process. I will do some searching for this and repost it here...
GTomb1
Hi i have tried to reformat the PC from the windows restore, it  fails to do a total restore( erasing everything) yet it did allow a restore keeping files and some apps.
Still as soon as i unplug i get BSOD. Did you by any chance manage to dig out that how too.
Kind regards
Graham
GTomb1
Excellent, yes i shudder to think how much junk is in my OS. Looking forward to learning something new.
Ledwardz
you aint the only one m8! I am in the exact same boat as you, have been receiving this error for past couple of month on my 2013 dell xps 9530. Hoping you get it resolved.
snorland
Following - I have a Dell XPS 9530 with the exact same problem.  This started just a few weeks ago.
GTomb1
Mine still isnt solved. I was hoping for a solution.
I recently bought a replacement, an XPS 13 9300. My BSOD pc is acting as a bridge between my network hard drive and TV.
If i unplug it i still get BSOD.
Ledwardz
I managed to get rid of mine. Had to burn operating system to a USB then reinstall (completely wipe every).
n_scott_pearson
Unfortunately, @fillermark, you are talking about a graphics problem when the OP's problem is a BSOD within one of the Intel RST drivers.
