I would disable the optane, reboot, enable the optane, reboot, and see if pinning is now available.
Doc
If that doesn't work, follow this process:
- Disable Optane.
- Uninstall the Optane software package
- Reboot
- Install the Optane package again (use later version if available)
- Reboot
- Enable Optane.
Hope his helps,
Hello SGrif5,
Were you able to check the previous suggestions?
Let me know if you need more assistance.
David V
A Contingent Worker at Intel
WIN 10 - PRO - I am a novice and I need more detailed help with this problem. Microsoft Support said to not worry about it because it in not needed.
I tried the instructions above (both of them), but it only allows modify or uninstall. It then says the installation source is unavailable..
Is there anyway to stop the pop ups or correct the problem?
As you see from my update above, when MS required a restart and update to my Win10 PC, that somehow fixed the problem. That's the easiest to do for you to start with. If that doesn't work, see the instructions above this that DavidV gave and try those.Good luck.
