Intel® Optane™ Memory
1391 Discussions
intel rts used for optane acceleration of secondary HDD broken with latest update
MJone11
after installing 16.7 RST would no longer open and i was getting random timed BSOD's stating DRIVER_POWER_STATE_FAILURE
after reverting back to 16.5 the app functions properly and the BSOD's have stopped.
yes i did try repairing it multiple times and also couldn't uninstall to perform a clean install due to optane acceleration being activated.
Hello FallenOnMyRifle,
Thank you for contacting Intel® Technical Support.
As we understand, you need assistance with your Intel® Optane™ Memory. If we infer correctly we will appreciate if you can provide us with the following information:
  • A screenshot of the "Disk Management" of windows showing all your HDDs and partitions.
  • We advise you to follow the configuration guide available in your original equipment manufacturer (OEM) to disable the Optane from your motherboard BIOS in case that you want to reinstall your OS.
We will be looking forward to your reply including this information.
Josh B.
Under Contract to Intel Corporation
Thank you for having contacted Intel Technical Support.
We have not heard from you since our last communication.
Please let us know if you need further assistance or if we can close this case.
Josh B.
Thank you for having contacted Intel support.
Since you have not posted any updates on your community thread, the thread will be marked as assumed answered.
You can still post any updates at any time and we will continue helping you in any way we can.
Josh B.
