Intel® Optane™ Memory
1401 Discussions
problem enabling optane m10 16gb
cchristos
i am facing a problem enabling an optane m10 16gb on an asrock z490 extreme4 witn windows 10 64bit. i installed the 1st place the optane memery driver (it automaticaly changed ahci to optane rst in bios) and the system rebooted. the disk is in gpt format. but still i cannot enable for any of my disks.  i have tried to install the rst files , but i get the errors i upload.
are there any clues?
JosafathB_Intel
Hello, cchristos,
Thank you for contacting Intel® Memory and Storage support.
As we understand, you need assistance with your Intel® Optane™ Memory M10 Series. If we infer correctly, we will appreciate it if you can review the following information:
1- Based on the SSU logs you shared with us, the Optane memory is not detected.
2- We advise you to contact your OEM (original equipment manufacturer) and to open a ticket in parallel since you are having issues installing the drivers available on their website.
https://www.asrock.com/MB/Intel/Z490%20Extreme4/index.asp#Download
3- Our recommendation is to check your motherboard manual or with your motherboard original manufacturer (OEM) about the M.2 configuration to connect the Optane memory, to uninstall your current drivers, and to install the latest packages on your OEM website (Intel Optane driver ver:17.8.0.1065_RS5). After installing this driver and the Optane is activated, install the Optane software available in the Microsoft* store.
4- Please, check the motherboard firmware version with your OEM. Install this firmware update if necessary, and try to activate your Optane.
https://www.asrock.com/MB/Intel/Z490%20Extreme4/index.asp#BIOS
Let us know the results.
We are going to follow up with you again next Tuesday, the 17th of November 2020, if we do not receive an answer from you. Please let me know if you would like to schedule a different date for the follow-up.
Josh B.
Intel® Customer Support Technician.
cchristos
i forgot to mention that i have an i7-10700 cpu, and neither the drivers or the rst work from the asrock site
cchristos
this is the log from the ssu
JosafathB_Intel
Hello, cchristos,
Josh B.
cchristos
thank you for your prompt reply. asrock tech has shown me that the mobo has three m2 slots an i was using the wrong one. now it works like a charm with optane memory from market place, BUT still i get errors installing the rst and the installer stays active at the windows startup. the log files are below.
cchristos
finally managed to get it working. since it works with the program from microsoft store there is no need to install this.
JosafathB_Intel
Hello, cchristos,
Thank you for your reply.
We are glad to hear that you were able to set up your Optane memory on your PC.
Based on the information you provide us, everything seems to be up and running on your PC.
We will proceed to close this thread as you already our answer as the best answer.
If you need assistance with any other Intel® product, please open a new thread.
Have a nice day.
Josh B.
A Contingent Worker at Intel®
