Intel® Optane™ Memory
1384 Discussions
¿puedo usar una memoria Intel Optane para acelerar un volumen RAID 0 existente?
JGlez
Cuento con un volumen RAID 0 con discos SATA III, ¿puedo instalar una unidad de estado solido Intel Optane para acelerer este volumen?
Hi JDGO_0416,
Thank you for posting in the Intel® communities.
You can indeed accelerate a SATA drive with the Intel® Optane™ Memory, however you can only accelerate single drives. Accelerating a RAID 0 volume is not possible.
I hope this information answers your concern.
Let me know if there is anything else I can help you with.
Have a nice day.
Diego V.
JGlez
Hola nuevamente.
¿Supongo entonces que tampoco es posible acelerar cada unidad que forma el arreglo RAID 0?
Hi JDGO_0416,
That's correct. You can only accelerate a single SATA drive with the Intel® Optane™ Memory. This means that you can have only one Intel® Optane™ Memory in the system to accelerate one SATA drive. It's not possible, for example, to accelerate 2 separate drives with 2 different modules, and then setup a RAID 0 volume with them.
I hope this clarifies the question. If you have further doubts, feel free to ask.
Have a nice day.
Diego V.
Hi JDGO_0416,
I'm wondering if there is anything else I can help you with regarding to the Intel® Optane™ Memory, or if I have answered all your concerns about it.
Diego V.
