Intel® Optane™ Persistent Memory
Examine Issues Related to Intel® Optane™ Persistent Memory
90 Discussions
Mémoire Intel Optane compatible RAID 1?
Fab-4416000
Bonjour, un SSD M2 Intel Optane 32Go peut il accélérer un RAID 1 de disque dur WD??
Azeem_Intel
Hi Fab-4416000,
Greetings for the day!
Hope you are doing well. In a RAID 1 setup, which mirrors data across two drives for redundancy, using an Intel Optane module (typically used for accelerating storage) in an M.2 slot will not accelerate the RAID 1 array.
Optane modules are designed to cache or accelerate single drives or non-RAID configurations. Since RAID 1's mirroring nature means that both drives contain the same data, acceleration features provided by Optane are not applied to the entire RAID 1 array as a whole.
If you have any further questions or need additional assistance, please feel free to ask.
Azeem_Intel
n_scott_pearson
32GB size would imply that we are talking about an Optane Module, not an Optane SSD. In this case, the answer would be No; Optane Modules are only used to accelerate performance of SATA HDD/SSD. Or are you talking about an Optane SSD that happens to have 32GB of Optane Memory on it? In that case, the answer is still No; you cannot form RAID1 array using a NVMe SSD and a SATA HDD/SSD (a RAID array can only have devices of a single type (NVMe or SATA)).
Hope this helps,
Fab-4416000
Bonjour, le descriptif exact est:
Intel Optane Memory M2 80mm, PCIe* 3.0 x2 (capacity 32Go)
Si je comprend bien, je ne peux pas accélérer un RAID 1 SATA avec un module Optane en M2, c'est bien cela?
Azeem_Intel
Hi Fab-4416000,
I hope you are doing well. Could you please let us know if this product was shipped with the system or purchased separately? This information will help us provide a resolution.
Azeem_Intel
Fab-4416000
Bonjour, il s'agit d'un produit acheté séparément.
Cdt.
Fabien
Azeem_Intel
Hi Fab-4416000,
This is the first follow-up regarding the issue (Hello Team, A RAID 1 (Mémoire Intel Optane compatible RAID 1?) you reported to us.
We wanted to inquire whether you had the opportunity to review the plan of action (POA) we provided.
Azeem_Intel
n_scott_pearson
No, that's not correct (though I realize that you could have assumed that from my (obviously poorly written) previous response). The Optane modules are a special case. The modules, running as NVMe devices, are being used to accelerate a (single) SATA HDD/SSD.
Azeem_Intel
Hi Fab-4416000,
Azeem_Intel
Azeem_Intel
Hi Fab-4416000,
This is the first follow-up regarding the issue (Mémoire Intel Optane compatible RAID 1?) you reported to us.
Azeem_Intel
Azeem_Intel
Hi Fab-4416000,
This is the second follow-up regarding the reported issue. We're eager to ensure a swift resolution and would appreciate any updates or additional information you can provide.
Please feel free to respond to this email at your earliest convenience.
Azeem_Intel
Azeem_Intel
Hi Fab-4416000,
This is the third follow-up regarding the reported issue. We're committed to ensuring a swift resolution and would greatly appreciate any updates or additional information you can provide.
If we don't hear back from you soon, we'll assume the issue has been resolved and will proceed to close the case.
Azeem_Intel
Fab-4416000
Bonjour, le souci est résolu. J'ai l'ai indiqué.
Cordialement.
Fabien
