Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
436 Discussions
I am just wondering if the H10 M.2 80 will work with Nvidia Jetson Xavier
AVolo2
https://www.intel.com/content/www/us/en/products/memory-storage/optane-memory/optane-memory-h10-solid-state-storage/optane-memory-h10-32gb-1tb-m-2-80mm.html
I know that Samsung turned out to work fine with Xavier [ https://devtalk.nvidia.com/default/topic/1039025/jetson-agx-xavier/m-2-nvme-compatibility/post/5288152/#5288152 ]
and I am investigating if H10 will work with the device.
Will it work as 32Gb + 1Tb?
As 32 Gb?
as 1Tb?
As neither of them?
Will it work under custom linux environment without any additional drivers?
Reference: https://devtalk.nvidia.com/default/topic/1039025/jetson-agx-xavier/m-2-nvme-compatibility/post/5400886/#5400886
AlHill
Ask Nvidia.
Doc
AlHill
Ask Nvidia.
Doc
AVolo2
Hi Al.Hill
Thank you for your response.
However, as you might have noticed I have already asked at their forum. And folks responded that they tested "1 TB Evo 960  that worked. I assume they have no information and neither experience with H10 hardware by intel. Therefore I asked at both forums : here and at their.
Andrey
JosafathB_Intel
Hello AVolo2,
Thank you for contacting Intel® Memory & Storage Support.
Please take into consideration that this is a 32 GB Optane memory with a 1Tb storage and the equipment needs to be validated by the manufacturer to be able to handle this hardware.
To answer your questions:
-Will it work as 32Gb + 1Tb?
32 optane memory + 1Tb storage will work in Windows 10*, the 32GB Optane memory for acceleration (not storage)and the 1Tb is designed to be used as a storage drive.
-As 32 Gb?
Yes, as a 32GB Optane memory for acceleration (not storage)
-as 1Tb?
-Yes, as a 1Tb storage drive to work accelerated by the 32GB optane memory part.
As neither of them?
In case that your motherboard is not compatible there is always a possibility that it may not detect the Intel® Optane™ Memory H10 with Solid State Storage (Intel® Optane™ Memory 32GB + Intel® QLC 3D NAND SSD 1TB, M.2 80mm PCIe 3.0)
Will it work under a custom Linux environment without any additional drivers?
Optane has been only tested, validated and it is only supported to work with Windows 10*.
As mentioned by Al Hill your best option is to ask the board manufacturer to get further information regarding compatibility and support of this SSD on your system.
We hope you find this information helpful.
Josh B.
A Contingent Worker at Intel
JosafathB_Intel
Hello AVolo2,
We were reviewing your community post and we would like to know if you need further assistance with your Intel® Optane™ Memory H10 with Solid State Storage Series or if we can close this community thread.
We will be looking forward to your reply.
Josh B.
AVolo2
consider the thread closed, please;
Thank you for your assistance
AV
AVolo2
I am trying to understand if linux on Jetson Xavier device will support https://www.newegg.com/intel-optane-16gb/p/N82E16820167426?recaptcha=pass
at least as just 16 gb ssd?
