Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
407 Discussions
Life of SSD and what happen when it hits TBW
fflin1
I have been doing quite a bit of research about SSD drives in the enterprise. I have some larger 16 drive arrays that I am using for virtualization. The question has come up do the Intel drives do anything to let me know they have reached the TBW number. I am running 50 VMs on the array and since there are multiple VMs the actual usage is very variable. I don't see anything happening for a few years but I also know budgets and they will not replace the drive until they have to.
Do the SSD drives go into read only mode, provide a warning that they are reaching the limit or nothing?
Hello komondor,
Thank you for contacting Intel® Technical Support.
To answer your questions:
We hope you find this information helpful.
Josh B.
Hello komondor,
Josh B.
Hello komondor,
Thank you for having contacted Intel Technical Support.
We have not heard from you since our last communication.
Please let us know if you need further assistance or if we can close this case.
Josh B.
fflin1
Yes the answer provided was very helpful. I do wish the other vendors I contacted were as forthcoming with the information.
Hello komondor,
Thank you for your reply.
It has been a pleasure to assist you through this process and we are glad to hear that you found the information we shared helpful.
As per your consent, this case is now close if you need further assistance please do not hesitate to contact us.
Josh B.
