Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
489 Discussions
Need API document for intel data center tool(isdct).
I need to get SSD serial number and number of blocks used and some of the SSD characteristics through my code.
So I need to use Intel.SSDFeatures.2.0.0.dll. Is there any API document available for development purpose.
186
Hello PrakasheRam,
We understand you would like to get a document in order to get some information. As of now, we are working with the proper team to get some confirmation of this and an answer will be sent over here soon.
NC
Hi PrakasheRam,
We would like to inform you that we don't have an API available for Intel® Data Center Tool.
However, you could use the SMART attributes to create the program. SMART is a standard and therefore you could base your code on it.
Some SMART attributes may vary depending on the SSD model, but there are some legacy ID's that would go through for most of the devices.
From us, you could use the SMART attributes available at Intel® Solid-State Drive Toolbox, Intel® Data Center Tool and the product specs.
Here are some interesting external sites for your reference:
http://www.t13.org/documents/uploadeddocuments/docs2005/e05148r0-acs-smartattributesannex.pdf http://www.t13.org/documents/uploadeddocuments/docs2005/e05148r0-acs-smartattributesannex.pdf
http://www.hdsentinel.com/smart/index.php http://www.hdsentinel.com/smart/index.php
Note: Any links provided for third party tools or sites are offered for your convenience and should not be viewed as an endorsement by Intel® of the content, products, or services offered there. We do not offer support for any third party tool mentioned here.
NC
