Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
497 Discussions
Optane SSD DC P4800X results in PCIe x2 connection
kunihito
I am using an optane ssd dc p4800x 1.5TB, but it only uses two PCIe lanes, so it is only half the speed of the specifications. The CPU is a Ryzen TR3960x, and I am using it by converting the PCIe x16 slot directly connected to the CPU to U.2. I have replaced the conversion adapter with a new one several times, but there is no change. Also, other p4800xes are connected to 4 lanes with the same conversion adapter and are performing as specified. What do you think is the cause?
Poojitha
Hi kunihito,
Greetings for the day!
Thank you for contacting Intel support. The product Intel® Optane™ SSD DC P4800X Series has reached its End of Interactive Support (EOIS). Intel no longer provides technical assistance, but you can continue looking for help from other community users. We recommend you search for an answer to your inquiry in the available self-help resources at Support for Intel® Optane™ SSD DC P4800X Series. More information about the EOIS status of this product is available at Customer Support Options for Discontinued Intel® Optane™ Solid-State Drives and Modules.
We appreciate your understanding!
Poojitha N
