Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
407 Discussions
isdct show -intelssd produces No results [545s / Linux]
S_5
I just got a new Intel 545s SSD, and found out it's using 512B block size by default. I'm trying to change it to 4096B using isdct tool.
I'm doing it all on Debian testing Linux (x86_64). I downloaded the tool from here: https://downloadcenter.intel.com/download/27497?v=t Download Intel® SSD Data Center Tool and installed 64-bit deb file.
Running the tool (as root) produces this:
isdct show -a -intelssd
No results
I enabled logging, and that's what I see in the log. So it's able to find the device, but something is still wrong.
01:56:49:555898 [info] DeviceFinder_SG.cpp(158) scanPhysicalDevices: Checking device: sg2
01:56:49:555909 [info] DeviceFinder_SG.cpp(164) scanPhysicalDevices: Device is a disk drive
01:56:49:561616 [info] DeviceFinder_SG.cpp(172) scanPhysicalDevices: Device is either not USB or USB scanning is enabled
01:56:49:561745 [info] DeviceFinder_SG.cpp(181) scanPhysicalDevices: Model: INTEL SSDSC2KW51
01:56:49:561757 [info] DeviceFinder_SG.cpp(182) scanPhysicalDevices: Firmware: 002C
01:56:49:561770 [info] DeviceFinder_SG.cpp(190) scanPhysicalDevices: Found /dev/sg2
01:56:49:561779 [debug] DeviceFinder_SG.cpp(191) scanPhysicalDevices: Creating Drive object
01:56:49:561816 [debug] DeviceFinder_SG.cpp(100) detectCommandPath: Entering
01:56:49:561830 [debug] CommandPath_ATA_SCSI_SG.cpp(239) test: Entering
01:56:49:561839 [debug] CommandPath_ATA_SCSI_SG.cpp(83) sendCommand: Sending command: NOP
Current Task File:
Feature / Error : 0x00 (0)
Sector Count : 0x00 (0)
LBA Low : 0x00 (0)
LBA Mid : 0x00 (0)
LBA High : 0x00 (0)
Device : 0x40 (64)
Command / Status : 0x00 (0)
Unused : 0x00 (0)
Flags:
Data In (From Drive) : False
Data Out (To Drive) : False
Data None : True
Device Diagnostic : False
DMA : False
Extended : False
Ignore Driver Limitations : False
Clear Prior Sticky Abort : True
01:56:49:561892 [debug] CommandPath_SCSI_SG.cpp(88) sendCommand: Sending command: NOP
0000: A1 06 20 00 00 00 00 00 ........
0008: 40 00 00 00 @...
SCSI Command Descriptor Block (Typical 12-byte CDB):
CDB 0 (Op Code): 0xA1 (161)
Command Code: 0x01 (1)
Group Code: 0x5 (5)
CDB 1 (Misc/SerAct): 0x06 (6)
Misc CDB Info: 0x0 (0)
Serv Action: 0x06 (6)
CDB 2 (LBA): 0x20 (32)
CDB 3 (LBA): 0x00 (0)
CDB 4 (LBA): 0x00 (0)
CDB 5 (LBA): 0x00 (0)
Log Block Addr: 0x20000000 (536870912)
CDB 6 (Alloc Len): 0x00 (0)
CDB 7 (Alloc Len): 0x00 (0)
CDB 8 (Alloc Len): 0x40 (64)
CDB 9 (Alloc Len): 0x00 (0)
Alloc Length: 0x00004000 (16384)
CDB 10 (Misc Info): 0x00 (0)
CDB 11 (Control): 0x00 (0)
Flags:
Data None : True
01:56:49:587112 [debug] CommandPath_SCSI_SG.cpp(210) sendCommand: Sense Data
Fixed Format Sense Data:
Response Code: 0x70 (112)
Valid: 0x0 (0)
Obsolete: 0x00 (0)
Sense Key: 0x5 (5)
Reserved (Byte 2, Bit 4): 0x0 (0)
Incorrect Length Indicator: 0x0 (0)
End-of-Medium Bit: 0x0 (0)
Filemark: 0x0 (0)
Information 0x00000000 (0)
Additional Sense Length: 0x0A (10)
Command Specific Information 0x00405104 (4215044)
Additional Sense Code: 0x21 (33)
Additional Sense Code Qualifier: 0x04 (4)
Field Replaceable Unit Code: 0x00 (0)
Sense Key Specific 1 (Byte 15): 0x00 (0)
Sense Key Specific 2 (Byte 16): 0x00 (0)
Sense Key Specific 3 (Byte 17): 0x00 (0)
Raw:
0000: 70 00 05 00 00 00 00 0A 04 51 40 00 21 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 p........Q@.!...................
01:56:49:587283 [error] CommandPath_SCSI_SG.cpp(245) sendCommand: Sense error. Response Code = 112. Sense Key = 5.
01:56:49:587304 [info] CommandPath_ATA_SCSI_SG.cpp(197) sendCommand: Response code is 0x70 . Assuming Fixed Format Sense Data
01:56:49:587316 [debug] CommandPath_ATA_SCSI_SG.cpp(220) sendCommand: Response
Current Task File:
Feature / Error : 0x04 (4)
LBA Low : 0x00 (0)
LBA Mid : 0x00 (0)
LBA High : 0x00 (0)
Device : 0x40 (64)
Command / Status : 0x51 (81)
Unused : 0x00 (0)
Previous Task File:
LBA Low : 0x00 (0)
LBA Mid : 0x00 (0)
LBA High : 0x00 (0)
Device : 0x00 (0)
Unused : 0x00 (0)
01:56:49:587372 [error] CommandPath_ATA_SCSI_SG.cpp(226) sendCommand: Task file reported an error (bit 0 or 7)
01:56:49:587383 [debug] CommandPath_ATA_SCSI_SG.cpp(261) test: Test result: True
01:56:49:587392 [debug] CommandPath_ATA_SCSI_SG.cpp test: Exiting
01:56:49:587399 [info] DeviceFinder_SG.cpp(105) detectCommandPath: Found a supported command path: ata::scsi_sg
01:56:49:587410 [debug] DeviceFinder_SG.cpp detectCommandPath: Exiting
01:56:49:587420 [debug] DeviceFinder_SG.cpp scanPhysicalDevices: Exiting
Hello Shmerl .,
Thank you for your interest in the Intel® SSD 545s Series.
The reason behind the output that you are getting from the Intel® SSD Data Center Tool is that the Intel® SSD 545s Series is a Consumer SSD, not a Data Center SSD. You can check the SSDs compatible with the tool here (https://downloadcenter.intel.com/download/27497?v=t https://downloadcenter.intel.com/download/27497?v=t):
Besides that, please keep in mind that our Consumer SSDs (https://www.intel.com/content/www/us/en/products/memory-storage/solid-state-drives/consumer-ssds.htm... https://www.intel.com/content/www/us/en/products/memory-storage/solid-state-drives/consumer-ssds.htm...) only support the standard 512 KB block size, so the change that you intend to perform is not possible.
If you are interested in this kind of modifications, please check our Data Center SSDs, https://www.intel.com/content/www/us/en/products/memory-storage/solid-state-drives/data-center-ssds.... https://www.intel.com/content/www/us/en/products/memory-storage/solid-state-drives/data-center-ssds.....
If you have any question, don't hesitate to contact us.
Andres V.
