Intel® Optimized AI Frameworks
Receive community support for questions related to PyTorch* and TensorFlow* frameworks.
Running int8 model on Intel-Optimized-Tensorflow
CHung
I read the article
https://www.intel.ai/accelerating-tensorflow-inference-with-intel-deep-learning-boost-on-2nd-gen-intel-xeon-scalable-processors/#gs.rzwuy9
It mentioned that the 2nd generation instructions such as AVX512_VNNI are optimized for Neural Network
I ran one of INT8 models in IntelAI
https://github.com/IntelAI/models/tree/master/benchmarks
Here is my environment
- Docker: docker.io/intelaipg/intel-optimized-tensorflow:latest
- CPU info
Architecture:    x86_64
CPU op-mode(s):   32-bit, 64-bit
Byte Order:     Little Endian
CPU(s):       96
On-line CPU(s) list: 0-95
Thread(s) per core: 2
Core(s) per socket: 24
Socket(s):      2
NUMA node(s):    2
Vendor ID:      GenuineIntel
CPU family:     6
Model:        85
Model name:     Intel(R) Xeon(R) Platinum 8259CL CPU @ 2.50GHz
Stepping:      7
CPU MHz:       1838.080
BogoMIPS:      5000.00
Hypervisor vendor:  KVM
Virtualization type: full
L1d cache:      32K
L1i cache:      32K
L2 cache:      1024K
L3 cache:      36608K
NUMA node0 CPU(s):  0-23,48-71
NUMA node1 CPU(s):  24-47,72-95
Flags:        fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss ht syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq monitor ssse3 fma cx16 pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm abm 3dnowprefetch invpcid_single pti fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid mpx avx512f avx512dq rdseed adx smap clflushopt clwb avx512cd avx512bw avx512vl xsaveopt xsavec xgetbv1 xsaves ida arat pku ospke avx512_vnni
I expect to run the Neural Network by the 2 gen instructions (AVX512_VNNI)
but it shows that the following optimized instructions are used:
AVX512F, AVX2, FMA
Is the docker image the optimized version to run Neural Network?
​How can I get the information whether AVX512_VNNI is used or not?
How can I compile the code provided by IntelAI by the 2 gen Intel instructions?
Which docker image can I use to run the program?
Thanks in advance
Jing_Xu
Duplicated thread. Please refer to https://software.intel.com/en-us/forums/intel-optimized-ai-frameworks/topic/843478#comment-1951298
