17251 Discussions
1:8 demultiplexer using two styles behavioral and structural modeling
I need vhdl codes for 1:8 demultiplexer using two styles behavioral and structural modeling
anyone can help on that please ?!!!
check the link for the pins detail foe 74ls138 1:8 demultiplexer
http://www.uni-kl.de/elektronik-lager/417703
Did you even try doing this assignment yourself? Asking for the solution is unlikely to get a response.
--- Quote Start ---
--- Quote End ---
Yes I did but am really stuck that's why I need help if you or anyone could help on that please
Post the problems - then maybe we can help...
--- Quote Start ---
--- Quote End ---
I need the codes for 1:8 demltiplexer by two styles
Behavioral and Structural modeling
The details of the 1:8 demltiplexer in this link
I appreciate your efforts for helping me dear
1:8 demltiplexer in two styles behavioral and structural
In need the codes for that
This is the type of demltiplexer am working on SN54 / 74LS138
Asking for code will not get a response. Have a go yourself and come back with problems.
here is the work i done
this is the structural modeling -
but there is some errors am expecting one of them in the nand statement
can you check out please
library ieee;
use ieee.std_logic_1164.all;
entity demux1 is
port(a0,a1,a2,e1bar,e2bar,e3:in std_logic; y0,y1,y2,y3,y4,y5,y6,y7:out std_logic);
end demux1;
architecture beh of demux1 is
component inv_6
port(a:in std_logic; b:out std_logic);
end component;
component nand_8
port(k1,k2,k3:in std_logic; z:out std_logic);
end component;
component and_1
port(c1bar,c2bar,c3:in std_logic; h:out std_logic);
end component;
signal i1,i2bar,i3bar,i4bar,i5bar,i6bar,i7bar: std_logic;
begin
u1:and_1 port map(e1bar,e2bar,e3,i1);
u2:inv_6 port map(a0,i2bar);
u3:inv_6 port map(a1,i3bar);
u4:inv_6 port map(a2,i4bar);
u5:inv_6 port map(i2bar,i5bar);
u6:inv_6 port map(i3bar,i6bar);
u7:inv_6 port map(i4bar,i7bar);
u8:nand_8 port map(i2bar,i3bar,i4bar,i1,y0bar);
u9:nand_8 port map(i5bar,i3bar,i4bar,i1,y1bar);
u10:nand_8 port map(i2bar,i6bar,i4bar,i1,y2bar);
u11:nand_8 port map(i5bar,i6bar,i4bar,i1,y3bar);
u12:nand_8 port map(i2bar,i3bar,i7bar,i1,y4bar);
u13:nand_8 port map(i3bar,i7bar,i5bar,i1,y5bar);
u14:nand_8 port map(i2bar,i7bar,i6bar,i1,y6bar);
u15:nand_8 port map(i1,i6bar,i5bar,i7bar,y7bar);
end beh;
library ieee;
entity inv_6 is
end entity;
architecture beh1 of inv_6 is
begin
b<= not a;
end beh1;
library ieee;
entity nand_8 is
end entity;
architecture beh2 of nand_8 is
begin
z<= ((k1) nand (k2) nand (k3));
end beh2;
library ieee;
entity and_1 is
end entity;
architecture beh3 of and_1 is
begin
h<= c1bar and c2bar and c3;
end beh3;
