10500 Syntax Errors
SAji0
Hi All,
I've been slowly knocking things out of my error list, but I'm stuck on these. Thanks in advance for any assistance.
My code:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL;   entity freq_div is Port( clockwide: in STD_LOGIC; reset : in STD_LOGIC; clock : out STD_LOGIC); end freq_div;   architecture Behavioral of freq_div is signal ctr_int : unsigned(25 downto 0); signal edge_int: STD_LOGIC; begin process(reset, clockwide) begin if(reset ='0') then ctr_int <= "00000000000000000000000000"; edge_int <= '0'; elsif rising_edge(clockwide) then if(ctr_int= 50000000) then edge_int <= not edge_int; ctr_int <= "00000000000000000000000000"; else ctr_int <= ctr_int+ 1; end if; end if; end process; clock <= edge_int; end Behavioral;   library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity tenbit_ctr is Port(reset: in STD_LOGIC; enable : in STD_LOGIC; clock: in STD_LOGIC; count_int: out STD_LOGIC_VECTOR (9 downto 0)); end tenbit_ctr; architecture Behavioral of tenbit_ctr is signal counter : STD_LOGIC_VECTOR(9 downto 0); begin process(clock, reset) begin if reset='0' then counter <= "0000000000"; Elsif(clock = '0' and clock'event) then If enable = '1' then counter <= counter + 1; end if; end if; end process; count_int <= counter; end Behavioral; library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; Entity Counterde1 is Port(CLOCK_50 : in STD_LOGIC; KEY: in STD_LOGIC_VECTOR (3 DOWNTO 0); SW : IN STD_LOGIC_VECTOR (9 DOWNTO 0); LEDR : OUT STD_LOGIC_VECTOR (9 DOWNTO 0); HEX0,HEX1,HEX2,HEX3 : out STD_LOGIC_VECTOR(0 to 6)); end Counterde1; architecture Behavioral of Counterde1 is signal count_int: std_logic_vector(9 downto0); signal clockwide: STD_LOGIC; signal clock : STD_LOGIC; signal reset : STD_LOGIC; signal enable : STD_LOGIC; signal HEXOUT : STD_LOGIC_VECTOR (20 downto 0); COMPONENT freq_div Port(clockwide: in STD_LOGIC; reset : in STD_LOGIC; clock : out STD_LOGIC); end COMPONENT; COMPONENT tenbit_ctr Port (reset : in STD_LOGIC; clock : in STD_LOGIC; enable :in STD_LOGIC; count_int: out STD_LOGIC_VECTOR (9 DOWNTO 0)); end COMPONENT; COMPONENT disp_ROM Port( address: IN STD_LOGIC_VECTOR (9 DOWNTO 0); clock: IN STD_LOGIC := '1'; q: OUT STD_LOGIC_VECTOR(20 DOWNTO 0)); end COMPONENT; LIBRARY ieee; USE ieee.std_logic.all;   LIBRARY altera_mf; use altera_mf;   ENTITY disp_ROM IS PORT ( address: IN STD_LOGIC_VECTOR (9 DOWNTO 0); clock: IN STD_LOGIC := '1'; q: OUT STD_LOGIC_VECTOR (20 DOWNTO 0) ); END disp_ROM;   ARCHITECTURE SYN OF disp_ROM IS SIGNAL sub_wire0: STD_LOGIC_VECTOR (20 DOWNTO 0); COMPONENT altsyncram GENERIC ( address_aclr_a: STRING; clock_enable_input_a: STRING; clock_enable_output_a: STRING; init_file: STRING; intended_device_family: STRING; lpm_hint: STRING; lpm_type: STRING; numwords_a: NATURAL; operation_mode: STRING; outdata_aclr_a: STRING; outdata_reg_a: STRING; widthad_a: NATURAL; width_a: NATURAL; width_byteena_a: NATURAL ); PORT ( address_a: IN STD_LOGIC_VECTOR (9 DOWNTO 0); clock0: IN STD_LOGIC; q_a: OUT STD_LOGIC_VECTOR (20 DOWNTO 0) ); END COMPONENT; BEGIN q <= sub_wire0(20 DOWNTO 0); altsyncram_component: altsyncram GENERIC MAP ( address_aclr_a=> "NONE", clock_enable_input_a=> "BYPASS", clock_enable_output_a=> "BYPASS", init_file=> "MULDE1.MIF", intended_device_family=> "Cyclone II", lpm_hint=> "ENABLE_RUNTIME_MOD=NO", lpm_type=> "altsyncram", numwords_a=> 1024, operation_mode=> "ROM", outdata_aclr_a=> "NONE", outdata_reg_a=> "UNREGISTERED", widthad_a=> 10, width_a=> 21, width_byteena_a=> 1 ) PORT MAP ( address_a => address, clock0 => clock, q_a => sub_wire0 ); END SYN;
AnandRaj_S_Intel
Hi Sami,
  1. Include begin and end Behavioral; statements in Counterde1 entity(Line 100).
  2. Line 103, USE ieee.STD_LOGIC_1164.all; not USE ieee.STD_LOGIC.all;
  3. Line 106, use altera_mf.all; not use altera_mf;
  4. Line 76 space between downto 0.
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity freq_div is Port( clockwide: in STD_LOGIC; reset : in STD_LOGIC; clock : out STD_LOGIC); end freq_div; architecture Behavioral of freq_div is signal ctr_int : unsigned(25 downto 0); signal edge_int: STD_LOGIC; begin process(reset, clockwide) begin if(reset ='0') then ctr_int <= "00000000000000000000000000"; edge_int <= '0'; elsif rising_edge(clockwide) then if(ctr_int= 50000000) then edge_int <= not edge_int; ctr_int <= "00000000000000000000000000"; else ctr_int <= ctr_int+ 1; end if; end if; end process; clock <= edge_int; end Behavioral; library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity tenbit_ctr is Port(reset: in STD_LOGIC; enable : in STD_LOGIC; clock: in STD_LOGIC; count_int: out STD_LOGIC_VECTOR (9 downto 0)); end tenbit_ctr; architecture Behavioral of tenbit_ctr is signal counter : STD_LOGIC_VECTOR(9 downto 0); begin process(clock, reset) begin if reset='0' then counter <= "0000000000"; Elsif(clock = '0' and clock'event) then If enable = '1' then counter <= counter + 1; end if; end if; end process; count_int <= counter; end Behavioral; library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; Entity Counterde1 is Port(CLOCK_50 : in STD_LOGIC; KEY: in STD_LOGIC_VECTOR (3 DOWNTO 0); SW : IN STD_LOGIC_VECTOR (9 DOWNTO 0); LEDR : OUT STD_LOGIC_VECTOR (9 DOWNTO 0); HEX0,HEX1,HEX2,HEX3 : out STD_LOGIC_VECTOR(0 to 6)); end Counterde1; architecture Behavioral of Counterde1 is signal count_int: std_logic_vector(9 downto 0); signal clockwide: STD_LOGIC; signal clock : STD_LOGIC; signal reset : STD_LOGIC; signal enable : STD_LOGIC; signal HEXOUT : STD_LOGIC_VECTOR (20 downto 0); COMPONENT freq_div Port(clockwide: in STD_LOGIC; reset : in STD_LOGIC; clock : out STD_LOGIC); end COMPONENT; COMPONENT tenbit_ctr Port (reset : in STD_LOGIC; clock : in STD_LOGIC; enable :in STD_LOGIC; count_int: out STD_LOGIC_VECTOR (9 DOWNTO 0)); end COMPONENT; COMPONENT disp_ROM Port( address: IN STD_LOGIC_VECTOR (9 DOWNTO 0); clock: IN STD_LOGIC := '1'; q: OUT STD_LOGIC_VECTOR(20 DOWNTO 0)); end COMPONENT; begin end Behavioral; LIBRARY ieee; USE ieee.STD_LOGIC_1164.all; LIBRARY altera_mf; use altera_mf.all; ENTITY disp_ROM IS PORT ( address: IN STD_LOGIC_VECTOR (9 DOWNTO 0); clock: IN STD_LOGIC := '1'; q: OUT STD_LOGIC_VECTOR (20 DOWNTO 0) ); END disp_ROM; ARCHITECTURE SYN OF disp_ROM IS SIGNAL sub_wire0: STD_LOGIC_VECTOR (20 DOWNTO 0); COMPONENT altsyncram GENERIC ( address_aclr_a: STRING; clock_enable_input_a: STRING; clock_enable_output_a: STRING; init_file: STRING; intended_device_family: STRING; lpm_hint: STRING; lpm_type: STRING; numwords_a: NATURAL; operation_mode: STRING; outdata_aclr_a: STRING; outdata_reg_a: STRING; widthad_a: NATURAL; width_a: NATURAL; width_byteena_a: NATURAL ); PORT ( address_a: IN STD_LOGIC_VECTOR (9 DOWNTO 0); clock0: IN STD_LOGIC; q_a: OUT STD_LOGIC_VECTOR (20 DOWNTO 0) ); END COMPONENT; BEGIN q <= sub_wire0(20 DOWNTO 0); altsyncram_component: altsyncram GENERIC MAP ( address_aclr_a=> "NONE", clock_enable_input_a=> "BYPASS", clock_enable_output_a=> "BYPASS", init_file=> "MULDE1.MIF", intended_device_family=> "Cyclone II", lpm_hint=> "ENABLE_RUNTIME_MOD=NO", lpm_type=> "altsyncram", numwords_a=> 1024, operation_mode=> "ROM", outdata_aclr_a=> "NONE", outdata_reg_a=> "UNREGISTERED", widthad_a=> 10, width_a=> 21, width_byteena_a=> 1 ) PORT MAP ( address_a => address, clock0 => clock, q_a => sub_wire0 ); END SYN;
