The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
15806 Discussions
10996 Verilog HDL error at <location>: parameter "<name>" has no initial or actual value
Tim10
I'm trying to pass a parameter down a chain of modules, but I get an error in top.v about the parameter having no initial nor actual value.
Any ideas? Simple typo?
Tim.
testbench.v
module testbench;   reg clock; reg in; wire out;   top #( .WIDTH(4) ) top_instantiation ( .clock(clock), .in(in), .out(out) );   endmodule
top.v
module top #( parameter WIDTH ) ( input clock, input in, output out );   bottom #( .WIDTH(WIDTH) ) bottom_instantiation ( .clock(clock), .in(in), .out(out) );   endmodule
bottom.v
module bottom #( parameter WIDTH ) ( input clock, input in, output reg out );   endmodule
ak6dn
Valued Contributor III
The default value of the parameter MUST be specified, it is not optional. So use: parameter WIDTH = 8 for example. You can always override it in the module instantiations.
Abe
Yes, @ak6dn is right. All parameters used within a module should be initialized with a default value. Then you can override them when creating instances.
module top #( parameter WIDTH = 1 ) ( input wire clock, input wire [WIDTH-1:0 ] in, output reg [WIDTH-1:0] out ); bottom #( .WIDTH(WIDTH) ) bottom_instantiation ( .clock(clock), .in(in), .out(out) ); endmodulemodule bottom #( parameter WIDTH = 1 ) ( input wire clock, input wire [WIDTH-1:0] in, output reg [WIDTH-1:0] out // reg is a keyword in Verilog, Do not use it as a signal/variable name. ); endmodule
Tim10
Thanks @ak6dn​ and @Abe​ .
Something that tripped me up is that if you synthesise the testbench (i.e. set testbench.v as the top level entity instead of top.v), then the parameter is passed down the chain even without default parameter values.
It is possible to use a parameter in a Verilog literal? e.g.
my_reg <= WIDTH'd0;
If not, where is the best place to go to request a Verilog language change and garner feedback on whether anyone would find it useful?
GuaBin_N_Intel
We have to follow rules defined in IEEE Standard for Verilog Hardware Description Language. For your question, that WIDTH parameter in the assignment could not be substituted correctly. You should use replication operation to make it work.
WIDTH'd0 become {WIDTH{1'd0}}
Here's https://en.wikipedia.org/wiki/Verilog contains some useful tutorial and example
