17241 ディスカッション
2 to 1 mulltiplexer
名誉コントリビューター II
2,127件の閲覧回数
Hi all.
I have problem during run VHDL code for 2 to 1 multiplexer. this multiplexer have 8 bit for input and output. while the select bit is only one bit. Here is my coding. However, there is error appear. Do you have solution regarding my problem.
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY part2 IS
PORT( SWX,SWY : IN std_logic_vector (7 downto 0);
s : IN bit;
LEDR : OUT std_logic_vector (7 downto 0));
END part2;
ARCHITECTURE dataflow OF part2 IS
BEGIN
LEDR <= (NOT (s) AND SWX) OR (s AND SWY);
END dataflow;
0 件の賞賛
4 返答(返信)
名誉コントリビューター II
733件の閲覧回数
Try
LEDR <= SWX when (s = '0') else SWY;
Cheers,
Dave
名誉コントリビューター II
733件の閲覧回数
Thank you Dave. It works. No error appear. I want to ask question. Is it possible if I still want used this code "LEDR <= (NOT (s) AND SWX) OR (s AND SWY);" in my architecture? Is there any method to use it. Or is not possible?
Thanks in advance Dave !
名誉コントリビューター II
733件の閲覧回数
--- Quote Start ---
--- Quote End ---
The above code is asking the synthesis tool to do that for you. What the tool will do is essentially what you have written, but it needs to happen on a per bit basis, eg.,
process(s,SWX,SWY) begin for i in 0 to 7 loop LEDR(i) <= (SWX(i) and (not s)) or (SWY(i) and s); end loop; end process;
Note how this code loops over each bit in the 8-bit word.
Cheers,
Dave
名誉コントリビューター II
733件の閲覧回数
Ok. Noted. I already run the code and it works. Thanks dave!
返信
