Hi
I am using 3 wire SPI IP from the prime Software. I didn't found any document which says how to pass the data or how to use this IP. In this IP, Input side 3 wire SPI IP, which is Avalon memory mapped interface, consisting of data lines, clock, write, read, chipselect signals. Output side 3 wire SPI IP, having SPI interface, consisting of MISO, MOSI, SS_N, SCLK. I am using 5 slave to connect and communicate with 3 WIRE SPI. CAN ANYONE HERE PLEASE TELL ME HOW TO PASS THE DATA OVER 3 WIRE SPI????Link Copied
Chapter 5 of the "embedded peripherals ip user guide (https://www.altera.com/en_us/pdfs/literature/ug/ug_embedded_ip.pdf)" covers Altera's SPI IP core. See table 21 for the register map which you access via the Avalon MM interface.
Cheers, AlexFor more complete information about compiler optimizations, see our Optimization Notice.
